Is any of this normal?
Old Mar 3, 2015 | 12:07 AM
Sl0wbaltSS's Avatar
Trying to figure out why it feels like i'm getting random misfires without any codes coming up. My other cobalt did the same thing. Here's some random info from a fancy scanner tool I was able to use.
Note: GMS1 with catless DP with no 2nd 02 sensor, zzp intake tube, K&N typhoon filer, injen upper ic pipe, Is does have an hp tune to turn off cat warmup and disable p0420 and the 2nd o2 sensor. I have looked at the lambda on the scanner during a pull #yolo and it's from .95 to .87 which I think is GMS1 parameters. I didn't use hptuners on it, it came like this.
Incomming pics. I'll just link you guys to the imgur page. http://imgur.com/a/1Tzkx#0
Old Mar 3, 2015 | 04:03 AM
footballplaya3k's Avatar
How are those intake valves looking?
Old Mar 3, 2015 | 10:22 AM
tomj77's Avatar
Is it like jerking a little while u drive on and off, and more so if u are against a strong wind? If so, change ur maf sensor. Had that issue. New maf solved it
Old Mar 3, 2015 | 09:46 PM
Sl0wbaltSS's Avatar
I don't know... I'll see if I can get the intake mani taken off this weekend and get it looked at.
Old Mar 12, 2015 | 11:00 PM
Sl0wbaltSS's Avatar
le bump, would like some super scientist tuner help.
Old Mar 12, 2015 | 11:09 PM
Canadia's Avatar
Clean your valves
Old Mar 13, 2015 | 11:31 AM
09CobaltSS1's Avatar
Cylinders 2, 3, and 4 are doing some funky business there, particularly 2/3. It's tough to see exactly what's going on and why without more data though. Either way, you're likely seeing heavy injector misfire for one reason or another.
Old Mar 13, 2015 | 11:55 AM
cluelessk's Avatar
How's your fuel? Also that seems like a fair bit of mods for no tune. Could very well be the intake.
Old Mar 16, 2015 | 02:18 PM
08VRSS's Avatar
Looks like gms1 fueling to me if thats what you're reading for lambda. Thinking you need a touch up on your tune if you're running a decent amount of boost with those lambda targets too.
Old Mar 30, 2015 | 02:07 AM
Sl0wbaltSS's Avatar
Took off the brake booster line to the intake mani and the little pvc thing and look a wire and stuck it in there, jesus christ did that wire get dirty, had to clean it many times. I do need to walnut blast it, clean the combustion chamber, new spark plugs, clean the tb. Lots of maintenance
Solaris99
28
Mar 15, 2017 01:22 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
roth
Sep 26, 2015 12:16 PM
