Anyone with Cams yet?
http://tunersource.gmblogs.com/Racer...FO-SHEET-2.pdf
Decent info...from the article "LNF - Cannot be replaced by the GM Performance Parts cams set or any aftermarket cams set"
So if it was done it looks like you'd have to re-grind a stocker. The exhaust cam in the LNF comes from the same casting as the LE5 intake and exhaust cams though so it may be possible to re-grind an LE5 exhaust cam for use as an LNF exhaust cam. The design of the intake cam on the LNF makes it pretty much impossible to replace with aftermarket or from another Ecotec from what I've read.
If that is true a ported head should net some decent gains. Even on the stock cams. We can adjust them with HP Tuners so they act like longer duration cams.
With the fuel pump lobes incorporated into the LNF intake cam, no other existing cams can be run in it's place. The LE5 exhaust cam will swap in place of the LNF exhaust cam, but it's not much of an upgrade, if at all. It's about 1.4 degrees more duration, but about .006" less lift.
Actually, the LNF head is pretty much garbage as far as intake flow is concerned. It's not even close to the LSJ head.
We've done extensive flow testing between many different combinations. The LNF intake is by far a very poor contender.
I meant there is plans now.(Now that we know how poorly they flow.) We have a ported head finished and going on our car soon. We have a couple more LNF heads out in the shop. I'll check and see how soon we might have more done.
dude...the LNF is the greatest 4cyl to come from GM ever! it will be around for a while. Likewise, VVT and direct injection arent going anywhere, so future iterations of the ecotec probably wont vary much from the LNF
With the fuel scare... i can only see the ecotec getting more money put into it.. we will probably see one in a future corvette
Sad but true, i think someone will design cams eventually, and if not, just get one custom made, trust me, if you pay a cam company they will do it for you. It really isn't the time to be turning away business
comp cams has a set we can work with - either in bolt-in app or ECM modded app:
http://www.compcams.com/Cam_Specs/Ca...csid=1079&sb=2 (I ordered one)
http://www.compcams.com/Cam_Specs/Ca...csid=1080&sb=2
http://www.compcams.com/Cam_Specs/Ca...csid=1083&sb=2
Keep in mind that all flow benches will vary. These numbers are for comparing the LSJ to LNF only. These are for completely stock cylinder heads.
at 28"--LSJ I--LNF I--LSJ E--LNF E
.100"---76----67.5---72.5---68.5
.200"--152---131---138.5--137
.300"--216.5-164.5-156----164.5
.350"--232---170.5-158.5--170.5
.400"--242---167.5-161----174.5
.450"--247---165.5-163.5--177
.500"---------164.5----------179.5
