Anyone have the AEM meth kit installed
Old Jun 22, 2011 | 11:59 AM
Tgustafsonjr's Avatar
Just wondering if someone could show me a picture of how the nozzle is setup. Wondering if I should weld it or just drill a hole.
Thanks.
Old Jun 22, 2011 | 12:03 PM
BYT*SS*TURBO's Avatar
Best thing is to weld a bung to the Lower CP in front of the TB but you can also tap the pipe and get it to work fine!
Old Jun 22, 2011 | 12:21 PM
07BoostedG5's Avatar
^isnt welding excessive? like you said tap it and then use red loctite. then again I could see welding better cause there may not be much to tap there eh?
Old Jun 22, 2011 | 12:30 PM
Have you ever seen a nozzle spray when you hit it? It like to jolt around a bit. The bung on the CP would be even better since you can get more threads holding the nozzle. But that's not something you HAVE to do either.
The bung and welding shouldn't cost more then $50.
Old Jun 22, 2011 | 03:01 PM
slowstang's Avatar
Im running an ais stage 2 meth kit with a zzp charge pipe. I drilled and tapped mine but welding a bung onto the pipe isnt a bad idea at all either
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 04:49 PM
justinchinn
Oct 2, 2015 12:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
Sep 27, 2015 08:53 PM
