Anyone have HP Tuners scan log for a AEM intake?
I have my AEM intake on and car is running smooth like it was with the stock airbox. It pulls a lot harder up top now though. It feels really good. I have not logged it yet as I am waiting for the ECM to relearn the fuel trims. It feels a lot more responsive and has less part throttle bogging then when I had the Dejon intake on there.
It might require some slight retuning but at this point I believe that it is within 3% of stock.
Terminator2, As far as the intake is concerned, with a stock car, shouild I wait for this GM kit to come out before buying and installing the AEM intake? Will the feul trim be fine on stock car without stage kit? Right now I have K&N drop in, should I just stick with it? Just looking for an opinion and you seem to know what you're doing! I have a catted dp on order as well. I know my car will learn down until I get the kit upgrade.
I know, right?!?!
Ok, so my options are as follows
SRI - that option is out the window, too much heat soak
CAI -
Right now I have Clear Image's on order, they said they had 0 issues with fuel trimmings ... hmmm
Injen - loss of power across the band
Hahn - forget it
AEM - questionable
Stock Box w/ K&N drop in
CAI -
Hahn - forget it
AEM - questionable
I have been running without the snorkel with the stock intake and filter and am seeing the same MAF lb/min flow as I did with my Injen (32-34lb). My LTFT's were off a little, but it was easily fixed with some calibration.
The worry I do have running this combo is the velocity stack type effect the snorkel provides. And I haven't been on the dyno to prove whether or not I'm actually making more power w/o it.
Good to hear! The only thing that I'm not a fan of is the dry filter. With the Fujita oiled filter on my LSJ, I've never had a problem with rain etc. On my bud's Injen intake with dry filter, it got soaked to the point it was dripping wet. Not a good thing.
Very good. You have to lightly lube the end of the silicone coupler to slide it over the turbo inlet otherwise it will not slip on. The breather connection fits well but is a tad too long IMHO. I could grind it down if I wanted to. It looks huge compared to my 2.5" CPs at 3.25". I got the gray powdercoated and it looks a lot nicer than the polished one. IMHO the polished style looks cheap to me for some reason.
It could be an issue I have not driven it in the rain yet. I can fabricate a sheild if needed. I do like that the dry filters dont attract as much dust as oiled filters the dust just shakes off so to speak. The filter is bigger than most others too a 7" element instead of a 5" or 6".
Last edited by Terminator2; Jul 15, 2009 at 02:52 PM. Reason: Automerged Doublepost
Just curious if you knew of the top of your head...
I did last night and got +9 to +10 LTFT because the diameter is learger than stock apparently. The overall driveability is better than my Dejon though. It does stumble a little on cold startup but it might stop once it finishes relearning the fuel trims. I adjusted my MAF calibration table and will check the results tomorrow.
Let's roll up in one place the STFTs/LTFTs and maybe flow numbers that we've collected so far from the different intakes... even if they're the same ones but from different people, it'd be helpful to get a feel and maybe get a pattern down.
