Anyone know what this is about?
Old Aug 13, 2009 | 08:46 AM
msfitoy's Avatar
This seems too good to be true...a complete Injen IC and charge pipe set for $200?!?!? Not for LNF?
http://www.autoanything.com/air-inta...&from_search=1
Old Aug 13, 2009 | 09:06 AM
Shez's Avatar
What the hell? That sounds like an awesome deal. I'm skeptical though.
Old Aug 13, 2009 | 09:17 AM
northvibe's Avatar
Thats not injen components then. They dont make a IC for the SS, that I know of or can find... I'd stay hell a far away.
Old Aug 13, 2009 | 09:41 AM
Shez's Avatar
Well even if its just the piping it's still a good deal, no?
Old Aug 13, 2009 | 09:43 AM
msfitoy's Avatar
I'm not sure what you're getting if the descriptions is so out of wack...it does say that it includes the FMIC...hmmmm
Old Aug 13, 2009 | 10:11 AM
smokedyou19's Avatar
thats a really good deal.. but i doubt its real
Old Aug 13, 2009 | 10:23 AM
madlion's Avatar
this is just the charge piping for the hot side. you can get the part number on that website if you select a color then you google the part number. come on you guys!! 200 is not that bad.
Old Aug 13, 2009 | 10:33 AM
northvibe's Avatar
Why would you buy from a place that is mislabeling and looks shady?
Old Aug 13, 2009 | 10:44 AM
msfitoy's Avatar
Not buying this BS...this is way too much parts for $212 shipped...
Features
Push your vehicle's turbo engine past the limitations of timid stock parts with Injen's advanced Forced Induction Components
Upgrade each part one at a time, or do a complete overhaul for the greatest possible power gains
Up Pipe: Built from 2" T-304 stainless steel tubing with built-in O2 sensor bung and ˝" die-cast flanges, it maximizes exhaust flow for huge horsepower gains
Down Pipe: Crafted from 76mm mandrel bent stainless steel with a 1-piece collector, it eliminates exhaust restrictions for massive boosts in power
Cross Over Pipe: Wrought from T-304 stainless steel and a stainless braided flex pipe, it accelerates your turbo response by maximizing the exhaust flow between the 1 and 4 cylinder and the manifold collector
Front Mount Intercooler: Forged from T-6061 aluminum, it works like a radiator for air—cooling the intake charge for more energetic combustion with reduced thermal stress
Your Front Mount Intercooler requires no frame modification and retains factory fog lights
Intercooler Piping: Mandrel bent from premium T-6061 aluminum tubing, these tubes greatly reduce airflow restrictions
Injen Forced Induction Components are all backed by a 1-year warranty
Description
Better buckle up—your ride just got a lot wilder! With Injen’s lineup of Forced Induction Components mounted to your turbo-powered vehicle, you’ll be an unstoppable force.
Speed up your turbo’s response with Injen’s Up Pipe. This tough 2” tube maximizes your exhaust flow, and the ˝” flanges ensure an exact fit against your block.
Eliminate power-robbing restrictions with the Injen’s mighty Down Pipe. Wrought from 76mm mandrel bent stainless steel, it lets your exhaust flow freely to boost your horsepower.
For even greater turbo response, bolt on Injen’s Cross Over Pipe. Connecting the 1 and 4 cylinders to the manifold collector, this stainless steel tube lets spent gasses pass through rapidly to generate more power.
Keep your intake charge cool with Injen’s Front Mount Intercooler. This air radiator ensures optimal oxygen temperatures. For faster flow, get the matching Intercooler Piping. Every Forced Induction Component comes with a 1-year warranty.
Old Aug 13, 2009 | 10:50 AM
Shez's Avatar
Someone just buy it to make sure.
Old Aug 13, 2009 | 12:02 PM
wantedSS/TC's Avatar
NOpe, I'll put $$ it's just the CP. Plus they give you worm clamps!
ssilver's Avatar
It has got to just be the upper pipe.. just mislabeled through their generic application finder.. I have purchased a few items from autoanything before with good results..
Old Aug 13, 2009 | 01:11 PM
msfitoy's Avatar
If that's the case, someone is in for one big disappointment
Old Aug 13, 2009 | 01:53 PM
Mazdaboi318's Avatar
call them
