Anyone running a AN20NHT motor?
Old Jul 10, 2013 | 06:30 PM
cobaltssoverbooster's Avatar
Question Anyone running a AN20NHT motor?
If anyone has blown a motor and bought a new one with block stamp AN20NHT and has all the recent upgrades like external vacuum pump off the end of the exhaust camshaft; did you replace the ecu with a new regal turbo ecu or did you run the older Bosch ecu?
got a AN20NHT and every connector is the same but the internals have minor updates performed to them and id like to know if anyone has the Bosch ecu running it. I really dont want to splice this regal sidi ecu in.
Old Jul 10, 2013 | 09:58 PM
jarhead's Avatar
PM ZZP- I Emailed Matt when I was trying to figure out what the heck gm had put in to replace my engine after cracked block issue. My car was the lhu gen 3 block with LNF hybrid also as all replacement engines are after about 9/2011. Any ways ZZP sells that exact engine and have a option to drop it in a buick regal or an LNF for an additional 90 dollars so I am sure they know what needs to be done and maybe will have the parts you need to use in you're Balt hope this helps.
ZZP also staes the LDK can handle 500 hp so be happy!!!
Here are the Links to the AN20NHT at zzp
GM ACDelco - Complete LDK Engine #
ZZP 3800 Series Engine | 3800 Performance Engine Parts | Series 2 Down Towards the bottom of page.
Old Jul 10, 2013 | 11:34 PM
did you get yours from zzp? still using your 2008 ecu?
Old Jul 11, 2013 | 01:03 AM
jarhead's Avatar
No mine is just the block and a few other things it does not have the vacuum pump and they put a 5 qt oil pan on it not the 6.5 qt . There are quite a few of these out there now. I would rather have the ldk version but just having the stronger block is good. What I was saying is zzp has a option to put it in an lnf car or a regal and whatever they do to put it in a lnf costs an extra 90 dollars so must be something they do or remove or sensors or something anyway. I also bet they could answer you're questions about ecu info.
Old Jul 11, 2013 | 08:22 PM
ATLsilverSS's Avatar
How would one know what block one has? My engine was replaced maybe right around 9/2011
Old Jul 11, 2013 | 10:31 PM
tomj77's Avatar
well my engine was replaced last year so im sure I have the new one. and still the same ecu
Old Jul 12, 2013 | 10:24 AM
DirtyBalt09's Avatar
Where is the info to find out your type that was installed. My engine was replaced 2 months ago. I'd like to look for my own knowledge.
Old Jul 12, 2013 | 02:29 PM
ctn2mb's Avatar
I have the LDK from ZZP... I have the same LNF ECU... you wont have the oil level sensor... and you'll need 6.3 qts of oil instead.
Old Jul 12, 2013 | 02:54 PM
Well i only use 5qts so i guess i have a gen2 ????
Old Jul 12, 2013 | 02:57 PM
ctn2mb's Avatar
Yes, unless someone besides the dealer put a different oil pan. The gen3 comes with a 6.3 qt oil pan.
Old Jul 12, 2013 | 08:50 PM
jarhead's Avatar
No the replacement GM engine has 5 qt it is a gen 3 block franken lnf. If you're engine has been put in after about 10/2011 it is most likely the gen 3 block one tell tale is the front valve cover is about almost an inch higher than the rear. Where the lnf is equal height. Also the metal on the valve covers looks real different like a swirled metal look to it.
Here are a cpl posts to read about the differences.
https://www.cobaltss.net/forums/2-0l...rences-276906/
https://www.cobaltss.net/forums/adva...ck-lhu-289219/
Old Jul 12, 2013 | 10:05 PM
tomj77's Avatar
my valve cover looks the same cause they put my same red one one
Old Jul 28, 2013 | 04:40 PM
Seems as i have a hybrid with the 5qt oil pan. 5 qts comed right up to the last line on the dipstick right before the full mark. Not sure if another 1.5qts would fit or not.
The valve cover is taller in front than the rear. So that is my main indication. Im gonna try and verify the serial # on the block to be 100% certain
Old Jul 28, 2013 | 04:59 PM
royce777's Avatar
subd
Old Jul 28, 2013 | 05:44 PM
I have the Oil sensors but its wont be in use with this harness so i am positive your answer is what im looking for thanks a bunch mate!
Check the oil filter pod. on the front facing side (cobalt/hhr) of the filter there is a machined surface and it should have a stamping in it. A20NHT is one of the new stampings. the other is A20NFT. The only reason it will be an LHU is the the ethanol compatibility parts.
Hey the posts on the differences are cool thanks for updates.
Old Jan 1, 2014 | 06:12 PM
ORLANDO09SSCOBALT's Avatar
I just bought the LDK from ZZP...can you give me any info that has not been listed. HP?torque..anything useful.
Thanks
Old Jan 1, 2014 | 07:20 PM
tomj77's Avatar
where is the block stanped with part number to see what gen it is?
Old Jan 1, 2014 | 08:55 PM
Piston3's Avatar
Anybody know what the ZZP $90 charge is to setup the LDK for our cars? Probably ordering on Friday.
Solaris99
28
Mar 15, 2017 01:22 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ThoR294
Oct 4, 2015 08:44 PM
dieGone
Oct 1, 2015 06:27 PM
Stuff
Oct 1, 2015 05:47 PM
