Anyone see Matt's prototype dual injector setup?
Old Oct 14, 2010 | 11:53 PM
mkriebs's Avatar
Originally Posted by Matt M
Yes, they are angled nearly 45 degrees.
What CC injectors?? Surely small so you get good small droplets, I would assume. I am very interested to see where this goes. BTF never took his as far as I assume you guys will.
Are you getting number envy from hanging out with Ryan too much? :P Are we going to see a 600whp LNF soon? God I hope so!
Old Oct 15, 2010 | 12:05 AM
Matt M's Avatar
I have 60s in the intake right now.
The next step is cam testing.
Old Oct 15, 2010 | 12:06 AM
mkriebs's Avatar
Two thumbs up to that. Been trying to get that ball rolling forever now, just can't find the right company to work with. Its been said there aren't many gains to be had from changing cams out, but I beg to differ. There is ALWAYS room for improvement.
Any plans for a bigger turbo??? Lol.
Old Nov 21, 2010 | 06:02 PM
gone_in_10_sec's Avatar
Matt - Any updates on this?
Old Nov 21, 2010 | 11:19 PM
Matt M's Avatar
We are working on developing a plug n play setup that doesn't require any ECM changes. It will take some time to develop the electronics.
Old Nov 22, 2010 | 06:17 PM
Nice, I cant wait to purchase one for my build..
Old Jan 24, 2011 | 08:45 AM
SKY888's Avatar
Yes, mkriebs is right. BTF has been using secondary fuel rail with direct port injection on his solstice for some time now. Greaseyjockey with solstice gxp/GT3582r also uses the same concept. I believe both of them are using microsquirt and it starts spraying at high boost. No issues so far.
Anyways, Matt_M, any update on this?
I was wondering why you guys decide to go with only 2 injectors...........instead of 4 smaller injectors for more equal distribution?
also, what type of fuel controller are you guys using?
Last, did you guys just tap the gas line for the extra 2 injectors fuel source?
thanks!
Old Jan 24, 2011 | 09:10 AM
Ryan@zzp's Avatar
thanks!
2 inj?
Old Jan 24, 2011 | 09:36 AM
Matt M's Avatar
thanks!
Lots of people use custom setups to add more fuel delivery headroom, but that doesn't really pertain to what we do. They are just buying a more universal product and adapting it over. We design and build our own parts specifically for the vehicle we are working with with the customers' needs in mind.
Where did you read that we are using 2 injectors? The pics that we posted showed a port injection fuel rail with an injector in every intake runner.
Yes, it runs off the same fuel line, but it could easily be connected to a meth tank/pump.
Old Jan 24, 2011 | 09:41 AM
SKY888's Avatar
Originally Posted by Ryan@zzp
2 inj?
sorry, Im at work, and can't see any facebook photos or any other photos. After Matt post the couple of photos I can see there are 4 injectors
due to the title being "dual injector" set-up, I assumed/thought it was only 2 injectors.
Old Jan 24, 2011 | 09:42 AM
  #36
SKY888's Avatar
@ Matt M......now I can see the photos. Thanks for posting it.
just like what I mentioned to ryan, I just saw this post today, and it's unfortunate I'm at work, and they block facebook, and other stuff.
Anyways, let me know when you guys finished developing this. I'm very interested in a plug and play set-up
will you guys also accept "core exchange"......regarding the intake manifold?
Old Jan 24, 2011 | 12:58 PM
  #37
blackvette101's Avatar
any chance you guys will be developing a new intake manifold to go along with this.
Old Jan 24, 2011 | 06:27 PM
  #38
mongorat427's Avatar
Very interesting. Does this use a second LNF injector rail and injectors ?
Old Jan 24, 2011 | 07:35 PM
  #39
cmiller8006's Avatar
No just a standard port injectors. But they are working on using the lnf PCM to run them
Old Jan 24, 2011 | 07:37 PM
  #40
whyyoumadson?'s Avatar
believe its an le5 injector rail and injectors? correct me if im wrong...like cmiller said lnf pcm
Old Jan 24, 2011 | 10:16 PM
  #41
Matt M's Avatar
Yes, the current setup is using an LE5 rail and injectors. The prototype controller has it's own drivers and adds fuel based on MAF readings. I'm under 30% duty cycle on the direct injectors at 400whp running E85, so it is working well so far. It also runs on DI only until ~25 lbs/min to maintain the best fuel economy and drive-ability possible.
Old Jan 25, 2011 | 05:31 AM
  #42
I guess I better save my LE5 rail and injectors.
Old Jan 25, 2011 | 10:45 AM
  #43
freakta's Avatar
very nice. ive got a similar setup on my lsj but with meth instead of reg fuel
Old Mar 6, 2011 | 01:14 PM
  #44
SKY888's Avatar
bump for updates
Old Sep 26, 2011 | 08:53 AM
  #45
SKY888's Avatar
ZZP are you guys still using this set-up together with your stage 1 w/ upgraded fuel lobe?
or no longer using the secondary fuel injectors?
thanks!
Old Sep 26, 2011 | 09:42 AM
  #46
Matt M's Avatar
thanks!
With our high lift pump lobe cams, we can get well past 450whp and more than 425 ft lbs on E85, which supports most builds. Going beyond that, we set up a single additional injector and drive it with an adjustable controller that adds fuel based on boost. We have surpassed 600whp on this setup.
Old Sep 26, 2011 | 10:25 AM
  #47
SKY888's Avatar
thanks for the response Matt.
thanks for the PM reply as well.
Old Sep 26, 2011 | 06:33 PM
  #48
matt, Is this fuel setup available now to purchase?
Jan 12, 2016 12:01 AM
patooyee
Oct 15, 2015 05:11 PM
cw383
Sep 30, 2015 12:41 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
Sep 27, 2015 08:53 PM
