Average gas mileage for tuned LNF's
my tune is on..Term did a great job, and like i said, its better than before i was tuned.
I was trying to get a miles per full tank guys, so posting up 25-35mpg doesnt really tell the whole story of a full tank of gas, but if it was like that, it would be 300-400 miles to a tank...
to continue on though, I never really run a FULL tank through the car so it never needs the 12.5 gallons.. i always fill up when it gets under or around 1/8 tank.. that said it still seems odd how your numbers are still that low... tuned or untuned, when staying out of the throttle you should be getting decent mileage.. just matter of thinking what could be the issue here
I use the "myCars" app n heres my current numbers if these trends mean anything to you and your driving habits
Average since buying the car in April:
27.77 MPG
BEST:
#1 93 oct, 10.91 gallons, 347 miles, 31.79 MPG over 2 days, 95% HWY
#2 93 oct, 10.79 gallons, 332 miles, 30.76 MPG over 1 day, 95% HWY
WORST:
#1 91 oct, 10.49 gallons, 250 miles, 23.83 MPG over 10 days, 10% HWY
#2 91 oct, 10.43 gallons, 252 miles, 24.17 MPG over 7 days, 30% HWY
27.77 MPG
BEST:
WORST:
thats excellent^^^...my car is nowhere near that, and like i said, i am on only the best 93 gas...
my vacuum seems fine at -16 with a/c on and idle, and -22 when driving. i keep boost @ 5psi or less since i shift at 3k rpms...Dunno what the issue is, but obviously I need to start troubleshooting...i'm gonna start with the fuel filter and make sure the purge solenoid is still good too, since i have replaced it 3 times in 12k miles!!! isn't there another solenoid in the rear of the engine too???
They are within 2% of zero everywhere. His car was showing very good mileage when cruising when we were tuning it. I drove it some and at 60 MPH in 5th it was seeing 36-38 MPG.
Just out of curiosity, have you noticed anything wierd with his cam positions in the logs by any chance? Like fluctuations, static position, or not fully going to a commanded position?
omg dude, no **** keep it outta boost, like i said it was mostly out of boost but sometimes gets up to 5psi....lol, common' man...haha
So, i am gonna replace the vent solenoid, purge solenoid, and fuel filter to start...
I'm running a Term2 tune since labor day and my mileage is over 300 a tank full. I'm not light on the gas pedal either. There is no way I'd believe the tune is bad.
I don't know how a restrictive/restricted fuel filter would do it. I'd lean toward the latter two.
Yeah those purge solenoids can cause bad mileage. One of the HHR SS I tuned gained 5 MPG when he swapped his purge solenoid.
Not sure if this has been mentioned yet, but when was the last time you cleaned / changed your air filter?
I get between 27-30mpg driving to and from work...it mostly long roads no lights but stop signs..especially driving around base..its kind of hard to explain.....got 32mpg coming from Sacramento couple weekends ago and I had to some serious up hills...like had to downshift uphills...range on fill up was 400+
do you mean driving loads as in stress on drivetrain components or drivings loads as in demand from the engine?
I have very similar problems as you Aaron. My mpg has just recently dropped to about 22 and I'm getting about 195 to a tank. I was going to clean my k&n this weekend to see if it helps. Let me know if your find anything else. I hate burning through sooo much gas.
