Bcm
BCMs bond for life. Once programmed to a vehicle, they cannot be programmed to a different vehicle. With our cars, you have to actually disconnect the ipc and then use tis2web to program it and set up vin, mileage, and sdm identification. But that can only be done with a new one, one its programmed once, thats it.
tell who ever is trying to program it to disconnect the ipc and reprogram otherwise the bcm will self populate miles based on ipc input. If its a dealer, tell them to look up document id#2074175
