View Poll Results: Best Intercooler?
Voters: 73. You may not vote on this poll
Best Intercooler?
once hptuners unlock more fueling table i will probably purchase a brand new k04 and have it upgraded then send my stock one back for same work and just sell the one on my car now for a good price!
or get a new car! lol
Yeh thats my thinking as well. The only reason why I would buy it is because CrazySteve's and Hahns have bent entry's and exits. All the rest are squared. I wish someone would track down the core dimensions and HP rating for each IC. Maybe someone could through in some IAT2 stats too.
My old F350 SuperDuty had a smaller IC than the SMAX big core, and after all the stuff I did made a shitload more power than a Cobalt
That thing is obnoxiously big. Sometimes bigger is better, but to an extent!
BUT TOO big causes added stress on the turbo...
It's finding that fine line between too big and not big enough... The HAHN seems too big... IMO the Synapse is too big too... but flows exceptionally well due to the fantastic Garrett core
the smax has 2 IC's the big one and the stock replacement on that doesnt require modding the impact bar...dyno results were posted for both intercoolers by the same member who tried them both out
https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/s-max-intercooler-dyno-results-183143/
This test you mean?
Runs #3 vs. #6 don't do a good job of selling the smaller IC. Peak power was less than the OEM IC with cooler IAT's to its advantage even.
Before someone flames me, I have no horse in this race mmmmmkay
This test you mean?
I think its 28 actually. Regardless, I think these are all the dimensions of the IC list above.
525 CI - Stock 28*6 1/4*3
672 CI - Synapse 24*8*3.5
672 CI - Dejon 24*8*3.5
848 CI - Hahn 26.5*8*4
864 CI - CraySteve 24*12*3
960 CI - S-Max OEM 30*8*4
1440 CI - S-Max Tuner 30*12*4
The S-Max Intercoolers are estimated core dimensions, judging by pictures. The numbers are listed in the S-Max thread, but I think the length isnt the actual core length but the actual intercooler length. I have posted what I believe to be core dimensions ONLY.
Metal to metal ends on mine I got 27.25" but either way it is long but not very tall or thick.
If we're going off of just CFM of the k04 at 22 PSI, we wouldn't need a core any bigger than 12*6*3 inches, but I doubt how well it would actually cool. *These numbers are based off of Bell Air-to-Air Intercooler Cores.*
Weirddddd. I measured mine 3 times, and I keep coming up with 28. Maybe my stocker is bigger, or my tape measure is broken...damn chinese manufacturing.
With my Synapse at 22 psi they are 87-90* at WOT. Sure we don't need bigger, but the smaller heat soaks much much quicker!
Exactly. I completely agree. We just need to find that perfect balance, of size and cooling. Maybe Synapse and Dejon have it right. I just dont like the flow design. Combine CrazySteves ends and use Synapses core. Perfect IC, IMO
what about if i was to buy this core http://www.cxracing.com/mm5/merchant...gory_Code=INCO and get it fabricated to fit my car??? Wonder how this would work out
the core size is 22x8x3.5 and has a ci of 616 overall size is 28x8x3.5
Last edited by DoMiStIc_RuSh_06; Oct 11, 2009 at 01:37 PM. Reason: Automerged Doublepost
As of now, being that I'm gonna keep the stock turbo for awhile, I'm just gonna keep the stock intercooler.
