Best location for meth port?
Advance apology, I know ive seen this covered before, my search bar doesnt seem to be working properly tonight. On an LNF, where is the best place to put the spray nozzle? Im getting ready to see if anyone has a BYT TB spacer with the built in port they are looking to sell, but I wanted to confirm thats the best place. Thank you.
How would the maf get wet if its post maf? Wouldnt the charge air be enough to keep the meth upstream of the maf? Especially in a provressive system that is only spraying under boost
I would assume the moment after the throttle plate closes and there is still boost in the pipe, the sprayer still sprays for a short time as well as the fact, most those nozzles drip a bit after spraying. I could totally see how the MAF would get wet from it especially where the MAF is located on those type of setups.
