bet this isnt good
Old Apr 22, 2011 | 11:01 PM
jaygo7007's Avatar
Originally Posted by Zander916
130# seems pretty low.
Example, I have TWO cracked pistons. One was COMPLETELY shot... only 30#. The other that was cracked (ring land was floating between the rings) read 128.
The plugs look fine to me though but that 130# is what would worry me.
how did you fix your problem?? replace the ring lands or pistons
Old Apr 22, 2011 | 11:06 PM
Zander916's Avatar
It's in progress right now but yeah. New pistons soon and some machine work on the block. Boring about 20 over.
Old Apr 22, 2011 | 11:07 PM
HHRSSouth's Avatar
Keep us posted on the out come of your problem, I'm very interested in the "normal" oiling of your IC tract.
My car must be abnormal, since I don't have oiling like that with a bigger turbo and more psi.
mexi_loco's Avatar
my brother's mazda has the exact same turbo, and he tells me that those turbo's are known for oil leaking out of them. Something about bad seals from the factory. Their remedy is to switch to a thicker viscosity oil. And that's recommended from Mazda as well.
Old Apr 22, 2011 | 11:08 PM
jaygo7007's Avatar
what route did you go to replace the ringlands. aftermarket?
Old Apr 22, 2011 | 11:09 PM
Do_WorkSS's Avatar
I have oil in my intake tube...a little bit of blow-by out of the CCV is normal. The plugs are of course going to scortch a little bit because they are subject to extreme heat.
Old Apr 22, 2011 | 11:11 PM
jaygo7007's Avatar
im picking up the mpx catch can in the morning....if they have some in stock.
is there a how to install for those?
Old Apr 22, 2011 | 11:12 PM
mexi_loco's Avatar
they are pretty straight forward to install. But yeah there should be a how to on here some where
Old Apr 22, 2011 | 11:14 PM
jaygo7007's Avatar
im basic when it comes to this stuff lol
Old Apr 23, 2011 | 12:27 AM
ronn's Avatar
Originally Posted by HHRSSouth
Uhh that middle 40k plug doesn't look fine to me.
I hope you bent it back like that on top, and the wire coming out of the insulator looks half gone?
I assumed that he did that when I said plugs look fine.
Old Apr 23, 2011 | 12:37 AM
  #36
ronn's Avatar
Well, I didn't take a good look at this pic. This does appear to be a bit much..could be from Turbo oil seal as it recirculates air into intake (BPV).
Old Apr 23, 2011 | 10:44 AM
  #37
HHRSSouth's Avatar
I was basically adding the oil in that picture plus the oil in all the other different pictures (the ones not the same) together.
Thats why I said it seemed excessive.
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
Trav3480
Oct 1, 2015 08:17 PM
jas09ss
Sep 26, 2015 01:06 PM
