Blew off stock charge piping
Old Dec 24, 2009 | 04:38 PM
lifeguard15's Avatar
I was WOT in 2nd gear when the car suddenly bucked, I immediately let off and coasted to the next stop light. No CELs, but when the light went green I discovered I was in limp mode.
I made it to my friend's house and popped the hood. My IC/charge piping is super loose where it bends and runs straight down to the intercooler, but I didn't have sufficient light to see where it's supposed to attach. I'm guessing it popped off under WOT. Likely or possible?
Easy fix? I tried getting under the car last night but that's sure as hell not happening without ramps or stands. And now it's lightly snowing so it's not a driveway project anymore.
Old Dec 24, 2009 | 04:46 PM
PRND3L's Avatar
there is a buliten or a recall on the plastic fastener that holds it down. Many have just used a Zip tie and its fixed. The search button is your friend!
Old Dec 24, 2009 | 04:52 PM
Only when it works. Sound like a zip tie will be FTW this time.
Edit: I've already had GM Recall# 09126 done if that's what you're referring to.
Old Dec 24, 2009 | 07:02 PM
rukkee's Avatar
When I got my car home the first thing i did was tighten the charge pipes on the intercooler and at the turbo. They were practically finger tight so it wouldn't suprise me if they were just loose . Carefull on the intercooler thou.... the plastic ends can crack.
If you had the recall the Zip tie mod shouldn't be necessary
Old Dec 24, 2009 | 07:36 PM
iboost's Avatar
I've had my aftermarket pipe pop off the turbo and what happend was I got CEL and my car wouldn't start at first. Then I got it to start and I just crused and made sure nothing else would happen...
Old Dec 24, 2009 | 09:16 PM
Stamina's Avatar
There was a recall. The dealer will now install a more substantial fastener. Last time I took my car in, they put the fastener on there despite my aftermarket charge piping, so they could check off that they had done it.
Old Dec 25, 2009 | 12:33 AM
I've had the recall done. I'll just take a look at it tomorrow once I get my hands on some ramps from a friend.
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
