block off plate question
Old Jul 15, 2010 | 05:38 PM
dino75's Avatar
Hey, imy check engine light is on because of my bypass valve. I was told a block off plate was the solution. I am running an aftermarket blow off valve. Also is there any difference between the hahn and the turbo tech block plates? Any help is appreciated. Thanks!
Old Jul 15, 2010 | 05:48 PM
peachpuff's Avatar
Yes you gotta cap the stock bypass valve if you're not using it, both of those plates look identical so get which ever one is cheaper.
Old Jul 15, 2010 | 06:29 PM
dino75's Avatar
Thanks man
Old Jul 16, 2010 | 02:50 PM
Supercharged Guy's Avatar
Yeah I believe the TTR one is cheaper and both the Hahn and the TTR do the samething, so save yourself money and go with the TTR one
Old Jul 16, 2010 | 06:29 PM
09BlueBaltSS's Avatar
Are you tuned for the bov? Its probly a maf code
Old Jul 16, 2010 | 06:36 PM
iboost's Avatar
I have a bpv block off plate for sale. Its Hahn.
I got a check engine when I put the block off plate on. It didn't "stop" the CEL. Vince can turn it off if your Trifecta tuned. If your not, I suggest tuning it.
Right now I'm running the stock bpv and the bov
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
Trav3480
Oct 1, 2015 08:17 PM
goaliemo
Sep 28, 2015 01:37 PM
