Blown K04 Maybe?
Blown K04 Maybe?
So im almost positive my K04 blew last night. Just got trifecta tuned and loaded a revision to the tune. Was driving normal and did about 2 pulls today in about 85 degree weather and noticed a weird sound almost like a pulsating of air while under full boost. Then im cruising along and I feel a sudden stumble in my engine. I try to build boost and get this loud whine. I get it towed home and inspect.
I listened to the turbo and it sounds like a blender. I checked the BPV and it was intact. Checked IC and CP with no visible cracks. Checked shaft play and had enough oil in the turbo inlet to leave about a 1-2oz pool on my garage floor. Had up and down play and also had what I think is a decent amount of in and out play. So im pretty sure its blown. Reading the thread linked below, I have pretty much the same symptoms. Prior to this I always noticed a small amount of oil in the inlet and a oil smell in the exhaust. What you guys think?
This thread is a pretty much exact match
https://www.cobaltss.net/forums/08-1...uzzing-302114/
Was looking at the zfr and installing looks like a pita. Saw this at zzp? Is it really that cheap and the exact same thing? Dealer wants $1400 for the stock k04
http://shop.zzperformance.com/store/...-Assembly.aspx
Is that everything needed? So just to confirm, shaft play in and out is bad correct?
What sucks is i was in vacuum when it blew
It was hot though
It was hot though
Figured. Can i reuse my lines? Or should I get the $75 coolant lines etc? My turbo has always had a small amount of play and oil. But this was a big amount of oil and in and out play I had never before seen. ZZP offer a warranty on the K04?
Yeah well the tune spikes at 24 then settles around 23. It only pulls about 8 degrees of advance at wot. I dont think its that on edge. I mean it is trifecta but its not the final tune.
Yeah but I did that on the stock tune so I didnt think to much of it. I hear the in and out play i found is the thrust plate and the excess oil in the inlet is probably a blown seal. Does that sound right?
