Blown K04 Maybe?
$700? Did you buy the zzp stock turbo and have them install it? Good deal then. Ive been on 24 psi for over 2 years now. no problems yet. 24 psi seems okay, I think there are just some turbos out there (a very small number) that are just bound to blow no matter what.
Nope, family friend is the service manager. New gm k04 and exhaust mani installed for 700. All parts ordered by the dealer
Quick observation, did about 2 pulls with my base tune and the turbo boosted to 22 twice. The failing turbo boosted to 24, is it possible the old turbo with bad seals and bearing required more boost to make the same amount of power?
Sent from my Samsung Galaxy S4 using CobaltSS
I had to, generally a cracked exhaust manifold isnt usuable anymore. Dude I paid 700 for everything installed. You cant even get the turbo from GM for that.
Reading > You
Not exactly sure didnt see it, but on the turbo side, right where it connects to the exhaust mani, there is a splitter in the center of the pipe kind of like an S. That had a crack right through the middle of it. Tech said the exhaust mani had a crack from inside to out. Didnt get to take the blown turbo
Yes i did, go back a page(if your own mobile) and read my reply to leemanfor about excess oil. I clearly state "bearings are shot, exhaust manifold is cracked"
Reading > You
Reading > You
What causes that? According to the tech, the exhaust mani had a separate crack. I dont mind, my payment amount didnt change before or after they told me the mani was cracked
not sure what causes it to crack but its not a big deal for the operation of the car. I think all the turbo cobalts have that crack. I havent even looked at mine and im certain its there. Not a big deal. The new one will crack too. Im sure the service guy didnt realize they all get that crack. he just knows it didnt come from factory that way.
Thats what im hearing
considering new turbos from GM are more than what you paid for both + install you didn't get screwed, but now when a tech tells you the manifold is cracked in the middle where it "scrolls" the exhaust to the turbo you know its a ok!
Thanks! Im curious about the crack in the exhaust mani though. I didnt get to see that one
here you go OP.
Normal Turbo Cracks - Pontiac Solstice Forum
its for the turbo, but the matched exhaust manifold does the same thing.
here you go OP.
I bought a new K04 from the Classifieds for $250 back when everyone was ditching their stock turbos. Keep an eye out and buy one just to have an extra. I haven't needed it, yet, but I'm on a 21 psi tune.
