Boost controller or wastegate actuator
Old Jul 5, 2017 | 01:48 AM
Tyler Lee's Avatar
So my wastegate is sometimes stuck open a little and I l put another boost control solenoid from a Volvo on my car same part the wastegate opened and closed, but it broke 2 days later I have a 2009 cobalt ss turbocharged tuned on e85 and 25lbs of boost I was wondering what boost controller I could put on there that I won't need tuning for i can't just throw it on there I don't know if it's just too much boost for a stock boost controller, but I just want to be able to throw it on and not go get it tuned thanks for the help
Old Jul 6, 2017 | 10:34 PM
tomj77's Avatar
problem with mbc is ur not gonna get any ramp at all if u ever go big turbo, just whatever psi u set it too, u will have in all gears. u will have to still tune it for whatever u pick because the boost will most likely come on differently than the ecu controlled boost. plus u need to make it so ur ecu thinks ur still using a solenoid. id just buy the proper solenoid if I was you. can get em at zzp, or just google efr boost control solenoid. its the same thing as the one on the k04, u will just not be able to mount it on the turbo, can relocate it away from that heat anyway, that's what I did, will probably last longer that way.
