Bouncing RPMs when coasting in nuetral
Old Aug 16, 2016 | 02:39 PM
royce777's Avatar
Having a weird issue with my sedan.
Its a fresh LDK swap. When I put my car in neutral and I am coasting at any speed above 20ish mph my RPMs will bounce between 500-1500. It idles fine at a stand still. Only when I'm moving. I recently noticed that my brake booster hose is dry rotted I ordered a new one waiting for it to arrive. No CELs. Car has a K&N intake and catback.
P.S. I know I spelled neutral wrong in the subject
Old Aug 16, 2016 | 03:02 PM
jdbaugh1's Avatar
If your brake booster hose is dry rotted and you have a vacuum leak it can cause your RPM to bounce but I would think that it would also do it when you are idling at a stand still. Is the idle RPM high when you are at a stand still?
Old Aug 16, 2016 | 03:18 PM
royce777's Avatar
nope it idles normal at a stand still and basically anything under 15-20mph
Old Aug 17, 2016 | 10:02 AM
CudaJoe's Avatar
since your cars in motion, air is moving by where ever the leak is and causing your rpm issue. It might even just be air hitting your MAF. curious. just a guess though. id guess there is a disconnected vac line somewhere.
Old Aug 17, 2016 | 11:14 AM
royce777's Avatar
I originally though something like this. But the engine came with all the lines hooked up (I did check them over). The car does have a k&N but I never had this issue with the k&n on my other car if it is the MAF.
what do these cars hold stock? Mine holds 15psi and sometimes when I really get on it in 4th I will see maybe 16-17psi?
Old Aug 17, 2016 | 11:30 AM
CudaJoe's Avatar
that sounds normal. 15 psi roughly, spikes to 16-17 psi.
I suggest not cruising in neutral lol.
Old Aug 17, 2016 | 12:39 PM
umrdyldo's Avatar
I agree these cars do not line coasting in neutral with or with clutch pushed in.
I have found that if you do that and then try to drop into gear it will flood and backfire. It's a fun sound, but it's not necessarily good.
Old Aug 17, 2016 | 12:55 PM
CudaJoe's Avatar
im fairly certain now that he mentioned he has an SRI, its just air hitting the MAF.
Old Aug 17, 2016 | 01:33 PM
royce777's Avatar
I don't understand though. my other lnf will coast all day in neutral and be fine.
I'm waiting for the brake booster hose and I hope that is the issue. but like you stated before it is definitely a vacuum leak.
the dry rotted part is right on the bend before it attaches to the intake mani. now that you said it has to do with air flow, I think it may be the issue.
Old Aug 20, 2016 | 09:21 AM
royce777's Avatar
I replaced the brake booster hose and it is still giving me the same problem
Old Aug 20, 2016 | 09:27 AM
63 Nova SS's Avatar
What are your afr's doing during this period? Have you logged it to see what's going on?
Old Aug 21, 2016 | 12:55 PM
royce777's Avatar
I rotated the filter and put the heat shield back in and drove it very briefly and everything seemed fine
nstieg88
Dec 14, 2022 02:04 PM
bigdogstokes16
Jun 6, 2016 09:30 PM
GreenStang
How to Guide
Jun 6, 2016 11:34 AM
metroplex
May 29, 2016 08:08 PM
Dougsterbob
May 20, 2016 12:14 AM
