Bov
Old Jun 24, 2011 | 04:26 AM
10Cobalt_SS's Avatar
Bov
Sooo if i change to a bov will it need tuning? will it effect any performance? and where can i get the block off plate for bypass valve and the charge pipe with the bov fitting most likely will get hks
Old Jun 24, 2011 | 11:29 AM
BooSSted's Avatar
Treadstone makes the best block off plate. There are a number of vendors that make charge pipes with a BOV flange. Just make sure you get one that will work with the HKS Valve. I believe the Dejon works with it.
You are going to need tuning and you're also going to need to relocate your MAF sensor to the lower charge pipe.
Personally, I don't think you should do it. These cars don't like aftermarket BOV's
If you're just looking for the sound, buy a K&N intake instead. It will sound exactly the same as an aftermarket BOV and work much better.
Old Jun 24, 2011 | 12:11 PM
BYT*SS*TURBO's Avatar
We've installed them on cars without a relocate and it works OK, def better with it relocated tho!
ineedacobaltss
Nov 7, 2015 02:25 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
breds2k
19
Sep 21, 2015 10:24 AM
