BOV Question
Old May 28, 2010 | 09:22 AM
mkulrey13's Avatar
BOV Question
Ok, i bit the bullet and purchased a HKS () I am installing all my new pipes today and BPV block off plate. Now the hose that use to go to the BPV, does that go to the HKS now?
Old May 28, 2010 | 09:53 AM
Supercharged Guy's Avatar
In for answers I will be installing mine soon so I need to know aswell
Old May 28, 2010 | 09:54 AM
ei3dag3's Avatar
yepp they do.
seen a few other installs.
just grab that line, and plug it into the plastic clear piece, then that line goes to the hks
can't wait to install my charge piping, and hks as well.
Old May 28, 2010 | 09:56 AM
Shez's Avatar
HKS should supply you with the hose and the little circular plastic thingy (filter?). Not sure if it's a different size or anything. I'm pretty sure it's whatever line that was going to your bpv is now going to your bov instead.
Old May 28, 2010 | 09:58 AM
mkulrey13's Avatar
Well ok i lied..i didnt buy it i traded HIDs for it.. No hose came with it but the filter did.
Old May 28, 2010 | 10:01 AM
CaseySS87's Avatar
Ur a business u don't do trades. Jk
Old May 28, 2010 | 10:03 AM
mkulrey13's Avatar
That is correct. What I need and my business are 2 different things
Old May 28, 2010 | 10:39 AM
Gestapo007's Avatar
read my post in here:
https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/help-flutter-coming-out-inktake-216654/
if you want to run a block off plate, you no longer have to "T" into anything. remove tan cap off stock BPV and rubber hose. Remove the spring and rubber piece, install spring and rubber piece on the block off plate to hold that seal shut in the BPV, screw in block off plate, then take the stock BPV black hose and just route it to your HKS, or if your HKS has a hose with filter on it remove the stock BPV hose and replace it with the HKS hose. pretty straight forward
Old May 28, 2010 | 11:12 AM
mkulrey13's Avatar
Thats what i figured. Altho i did not replace the spring with my block off plate. I just reinserted the rubber thing and tighten the **** out of it. Is the spring needed?
Old May 28, 2010 | 11:17 AM
Shez's Avatar
No spring is needed. Just the rubber circular diaphragm.
Old May 28, 2010 | 11:50 AM
Spooled's Avatar
Yea i just installed everything this past Sunday and i got the BOV from a friend and did have the hose or the filter and i just put the block off plate and the little rubber thing on and took the hose from the BPV and connected it to the BOV really simple.
ineedacobaltss
Nov 7, 2015 02:25 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
