BPV Flutter with K&N typhoon?
Old Jan 3, 2011 | 03:02 PM
MajorCB's Avatar
Originally Posted by Baron7700
exhaust is pointless with GMS1 Considering your still running the stock DP. get a DP and Intake + GMS1. I had that setup before i got tuned, and i can tell you each part DEF made the car quicker, cant tell you hp numbers exactly. I think next time i dyno ill switch back to GMS1 for a pull, but i dont have a gms1 with no mods on it so I dunno.
goos points.. thanks for the suggestions... did you have any CEL issues after these additional add-ons when mated with the GMS1?
Old Jan 3, 2011 | 05:00 PM
tom.g's Avatar
Originally Posted by peachpuff
The gm kit obviously does increase hp, think me and tom.g were originally talking mostly about the additional intake not giving a hp increase. While a lot of sites say that the learn down feature is disabled, can't say i ever saw anyone prove it with any actual facts or data.
Thats exactly what I was saying. GMS1 will obviously add power but an intake on top of GMS1 I don't think will add any real gains. A DP on top of GMS1 is a different story.
Originally Posted by Billy Baldone
I still think you're not fully understanding this.
GMS1 will give you more horsepower-yes
Adding an intake on top of GMS1 with no other tune will not add any more horsepowers-correct. So no there won't be 15 more.
I highly doubt your going to get an extra 15hp by just slapping an intake on to a GMS1 car maybe 5. A catless DP has shown benefits with GMS1 but an intake on a GMS1 car is just not a good idea.
Old Jan 3, 2011 | 11:25 PM
MajorCB's Avatar
ok.. I'm gonna toss it out there... an intake with a GMS1 .. not a good idea... is that because of the inconsequential gains? or because it negatively impacts the MAF and throws CEL's or something.. the DP was an idea, but I'm not sure how it would impact the warranty, if at all...
Old Jan 4, 2011 | 11:59 AM
tom.g's Avatar
It skews the fuel trims because the MAF cannot properly read the air from an aftermarket intake which is why a custom tune is needed to properly adjust the MAF to read the airflow from the aftermarket intake, the GMS1 tune does not do this.
As for the DP this is the single most effective bolt-on for our cars and has no negative effects on the car at all (read this: https://www.cobaltss.net/forums/2-0l...npipes-198998/).
As for warranty any time you put on an aftermarket part your taking a risk if they see a K&N SRI and worn down tires a lot of dealerships will jump to the conclusion that you have been abusing your car and can void your warranty claim, hell you can be completely stock and they can still scream abuse if they want to.
Old Jan 4, 2011 | 12:12 PM
CudaJoe's Avatar
DP is an exhaust component and has no important sensors responsible for how the vehicle calculates air/fuel mixture so the idea of getting a voided warranty over it is rediculous. I have not gotten my warranty voided yet. They have seen my ZZP charge pipe and my K&N intake. I had a boost leak and they took care of it under warranty.
Now if I had a messed up engine, I could see them trying to point the blame at the intake and I would probably swap that out. DP is an exhaust component, end of story.
Old Jan 4, 2011 | 12:37 PM
northvibe's Avatar
k&n intake on my gmstage 1 didnt cause any cel's, trims were skewed a little but nothing that will blow up my engine. I have hpt though and be tuning when its warm out.
Old Jan 4, 2011 | 12:39 PM
northvibe's Avatar
if my car goes in for warranty stuff, i'll probably throw on the stock intake and maybe charge pipe..... i dont want to deal with bs, its annoying and a waste of my time.
Old Jan 4, 2011 | 05:06 PM
CudaJoe's Avatar
now that I think about it, I put the stock airbox in for the boost leak, lol. but I definately had the charge pipe on their and Im sure they looked at it do to my problem being a boost leak.. right now I have electrical problems I think. Car dies after not being started for a week... My airbag said it needed to be serviced and then the service light just went out on my way home last night. wierd stuff. I cant go to a drive in movie theater without the car dying. Definately cant leave it in accessory mode for more than 5 minutes, lol. I might buy another battery just to see if I got stuck with a crap battery but I doubt it.
They might blame the power drainage on my interceptor guage saying its draining the battery or something.... OR they might blame my HID projectors... which would be stupid.
Old Jan 4, 2011 | 09:21 PM
ronn's Avatar
If you don't drive the car enough, the battery will drain and may not recover..sulfonation. My battery went dead only a couple months after buying it (used 8k mi). I found out the battery was replaced only about 6 months earlier, but it sat on the dealer lot most of the time. I guess they recharged it right before I picked it up (looked brand new), but it had discharged beyond recovery.
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
Sep 27, 2015 08:53 PM
breds2k
19
Sep 21, 2015 10:24 AM
SPOOLING
Sep 11, 2015 07:23 PM
