brakes wearing strange
so i picked up my brake pads yesterday for the rear, they were the wrong pads, thank u gm dealer, but when i took mine off today before i noticed i had the wrong ones, something was wrong with the picture, im not brake expert, but the inside pad on both side was all the way to metal, and the outside pad was almost no wear on it, that just doesnt seem right to me, what do u guys think
same here. I am almost 3/4 of the way worn through my second set of rear pads with 23K kilometers on the car. the fronts are like new! I'm not sure what the design flaw was with these rear pads/rotors but its not a good one. warrenty covered my first set, I doubt the second will be covered.
From an earlier post of mine...
FYI: 08-09 SS/TC Rear rotor GM part #
For those that need it and for future searches.
15921402 rear brake rotor 08-09 Cobalt SS/TC
Verified from Gmpartsdirect.com by my VIN Number.
Hawk HPS pads are:
HB478F.605 Disc Brake Pad; HPS Performance Street w/0.605 Thickness; w/Upper Notch And Spring; Rear;
I have the Hawk HPS rear pads on mine for about 10k miles now, no issues and rotors are fine. Make sure you lube the caliper pins when you have them off.
Hawk HPS pads are:
Have your flame suit cause here it comes:
Are you kidding me? out of the 10+ threads on how the rear brakes wear funny, and turns out exactly the same way you described, you still have the ***** to post this. come on, use the search button.
Out of all the times people have said it and i have said it and u still dont get it. The Search feature DOSNT WORK AND SUCKS ASS.
did that one get through???
My solution to the rear brake problem
https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/new-rear-tc-rotors-185369/
