buying a SS/TC thats hp tuned with mods.
what things should i be looking for as in problems with these im looking to get an 08 with these mods and it has been hp tuned to 315hp and 340 tq on dyno. anything that i should be looking for on this it has 25k miles
Hahn Cold Air Intake
Hahn 3" Catless Downpipe
Hahn 3" Catback Exhaust
Hahn Charge Piping (Hot and Cold Side)
Spare ECU w/ Custom HP Tune
Stock ECU
Stock ECU
Stock ECU
Stock ECU
Stock ECU
Stock ECU
Clutch would be on my mind with that. Hp range looks pretty *safe* though. Also, what is max *Peak* boost you see with this set up? Any CELs being thrown? Of course you want to look very carefully for oil leaks.
What did this person *do* with this car? Lots of drag racing would be a concern there.
I would really worry about how much the car was beat on. If the car still has warranty that would take some of the worry out of it. These cars can take allot of abuse with some people and very little with others.
I got an 08 with hp tune to 330whp and 392 wtq with much much more mods then that but the only hahn mod i got is the CAI and block off plate, and my clutch is new got a stage 4 clutchmasters. I get no cel's and peaks 25psi and settles around 22-23psi. Also i am a fully licence gm mechanic. and got good grippy tires on it with new front and rear brakes. even got a full corbeau forza racing seat set up with 5 point harness and bar. Also got a completey new transmission with about 2000kms on it and it still gots fully gm warranty. go no fluid leaks and common leaks have been repaired already and oil change done every 3000kms with mobil 1 synthetic.
i agree with northvibe to take the car to a experienced mechanic and have it inpected. they usually do a great job checking for issues and mine even did it for $50
sheldon729, how do u like those canuck springs. mine arrive on monday...
i love them actualy, it is a stiff spring rate tho.
My car also has 2 temp level cooler NGK pulgs in it for the tune and the lowest octane it can safely run off of is 94 octane (huskey premium)
I even put in the gm us version boost gauge aka Psi and got rid of the lame kPa.
Link to view car
http://www.cardomain.com/ride/3163531
Link to view car
The car is in great shape let me tell you lol! Very conservative tune, no clutch slip at all. No Oil leaks or CEL's (oil has been changed with Mobil 1). Never beat on it. Took it to the strip once, did about 5 passes. I even reinforced the shift linkage (and also have a spare stock one, along with the spare stock ecm).
And the tune sees about a max of 23psi, then settles to about 21psi consistently.
Link to view car
Link to view car
