Car is running too lean
Old Mar 31, 2012 | 05:33 PM
HyperFocus's Avatar
got a CEL light today..just came out of nowhere..p1287 i think it was? says its running too lean at idle...the Vaccum readings are fluctuating at idle, and im not boosting over 8-9 PSI in any gear.
only mod is k and n drop in..gonna try to clean the MAF..any other ideas?
Old Mar 31, 2012 | 07:10 PM
SSlobalt's Avatar
Sounds a little like the vac solenoid took a crap. Check that tube that runs down to the barb fitting on the coldside pipe. You're getting the "too lean" reading because there is a leak. When you say "came out of nowhere," what exactly were you doing?
Old Mar 31, 2012 | 07:20 PM
HyperFocus's Avatar
alright..dont think it has anything to do with the maf? i was just driving normally when it came on, actually coasting in neutral to a stop..i had noticed the reduction in boost before i got the CEL though, started happening yesterday
Old Mar 31, 2012 | 07:28 PM
Black_Mamba_09's Avatar
The first thing you need to is check for a vacuum leak. Check all your hoses, and then check your intake manifold. I would recommend using brake clean to spray the manifold, if the idle fluctuates thats were the leak is.
Old Mar 31, 2012 | 07:33 PM
SSlobalt's Avatar
You can run the boost leak test for any post-turbo leaks. See my sig for the How-to. We're not saying it absolutely isn't the MAF, but the only way to really check that is to replace it, unless the wiring going to the connector has been stressed.
Old Apr 1, 2012 | 07:43 PM
HyperFocus's Avatar
the connector is fine. i havent run a boost leak test, probably just gonna ask the dealer to do that..where is the vac solenoid excactly?
Old Apr 1, 2012 | 09:17 PM
SSlobalt's Avatar
Green circle at top of the pic is a tube coming out of the vac solenoid.
Old Apr 3, 2012 | 03:47 PM
HyperFocus's Avatar
well apparently the fuel pump was bad
Old Apr 3, 2012 | 03:56 PM
alerosaint's Avatar
subd just in case i run into this issue
Old Apr 3, 2012 | 09:49 PM
SSlobalt's Avatar
Strange that that made your vac fluctuate. HPFP or in-tank?
Old Apr 4, 2012 | 03:59 PM
HyperFocus's Avatar
high pressure..it was leaking. dealer said the car was actually running rich, even though the CEL was a lean code
vjoel2011
Oct 2, 2015 12:11 PM
hawkssoccer11
Sep 30, 2015 12:14 PM
ATOMbomb
Sep 11, 2015 10:48 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
Adam144
Sep 3, 2015 07:48 PM
