Car is a tiny bit hesitant
Old Aug 3, 2011 | 03:16 PM
Dart_SI's Avatar
Its nothing major. Just seems not so smooth at partial throttle. I recently recharged my k&n sri filter so im going to try cleaning the maf. Also, I think spark plugs might need replacing. Is stock plugs the best way to go? And what's the most effective gap? Thanks.
Old Aug 3, 2011 | 03:20 PM
u know mine kinda feels hesitant as well, kind of like the power surges in and out at lower rpms is that kinda like what u got? most ppl have recomended NGK (forget which #) plugs, but they don't rly need replacing unless ur missing or got cels u know?
cleaning the maf would be a good way to go if u just recharged, there could be dirt and moisture on it and that could cause issues
Old Aug 3, 2011 | 04:19 PM
JustACobalt's Avatar
just posted a thread about the exact same thing! studders a bit at low rpm while accelerating or cruising. changing spark plugs and cleaning sensors tmrw. go with stock plugs and gap them to .030
Old Aug 3, 2011 | 04:51 PM
Supercharged Guy's Avatar
Yup mines doing the samething and has been for a little while now...
I'm gonna try changing my plugs (back to stock) & clean my maf and see if that does the trick
Old Aug 3, 2011 | 05:01 PM
slowstang's Avatar
It seems like these cars start to get picky after racking up a few miles.
Recently, mine has been doing the same thing under part throttle. I've cleaned my maf and map sensors, replaced the evap purge valve, replaced wideband o2, battery, and now i'm replacing plugs. I went with NGK ltr6ix-11's which are one step colder...not saying they are the best plug or anything, it's just what im trying out in the car this time.
Old Aug 3, 2011 | 05:48 PM
Dart_SI's Avatar
It has been really hot and humid lately. Im only at 19k miles.
Old Aug 3, 2011 | 05:51 PM
07SSYellow's Avatar
Resident Post Whore/Troll
i had this issue also, when it was really rainy outside, my car would studder when i went into boost, might be the humidity, i changed my plugs and it did the same thing
Old Aug 3, 2011 | 05:53 PM
umrdyldo's Avatar
Same, I honestly think it's just the heat.
Old Aug 3, 2011 | 05:55 PM
07SSYellow's Avatar
not so much the heat but the moisture, cause it wasnt hot here when mine did it, but really rainy and humid
yeah mine does it only in high heat and humidity, its especially bad when its raining. maybe maf sensor acting up?
Old Aug 3, 2011 | 05:57 PM
07SSYellow's Avatar
could be it, or the moisture is making the MAF wack a little?
we dont get high heat here so idk but the raining part i do know, i just drive like a grandma when its raining
Old Aug 3, 2011 | 06:00 PM
yeah thats what i meant. its the worst in the rain for me, best on a dry night. i have a wideband gauge in the car and the afrs do seem a bit erratic when its happening (bouncing around 13.6-15.8ish)
Old Aug 3, 2011 | 06:02 PM
YelloEye's Avatar
Only when it's raining?
OP I don't recall your mod list but if you're still within 50hp of stock you should probably stick with the stock NGK ILTR5D plugs, they come pregapped don't bother measuring them or regapping. Rockauto.com has the best pricing on those.
Old Aug 3, 2011 | 06:03 PM
07SSYellow's Avatar
ya then i think we can assume it is the moisture sceweing the MAF at higher air flow causing it to studder
haha steve dont u remember it did it that night tom tried to race u in my car?
Old Aug 3, 2011 | 06:07 PM
seeyaass's Avatar
Not 100% sure on this but I culda sworn the gap was .32 or .42.. not sure haha.
Old Aug 3, 2011 | 06:08 PM
07SSYellow's Avatar
ya but when u run higher boost u gap them a little differently lol
Old Aug 3, 2011 | 06:21 PM
seeyaass's Avatar
Ahh okay
Old Aug 3, 2011 | 06:25 PM
it only happens under heavy load with your car? mine only happens at low rpm under light acceleration or cruising (between 1.5k and 2k rpm)
Old Aug 3, 2011 | 06:28 PM
07SSYellow's Avatar
it has happened under heavy load yes but ive noticed it putting around town also
Old Aug 3, 2011 | 06:53 PM
hmm its never happened to me under boost or over 2k. we must have different issues...
Old Aug 3, 2011 | 08:37 PM
Ch1ck3n's Avatar
I run stock plugs on stock gap with a 26psi tune on e60 with no problems
Old Aug 4, 2011 | 01:07 AM
i think i may have just figured out my problem. i had a shop replace the head with one that i bought. after reading about transferring the fuel pump and fuel feed pipe to the new head, i learned it is mandatory to replace the fuel pump o-ring, fuel pump gasket, high pressure fuel pipe, and fuel pump bolts. the shop failed to do any of those...
Old Aug 4, 2011 | 02:38 AM
DerekDTP!'s Avatar
hmmm, justAcobalt, i have the same issue.. just at cruising speeds, basically around or under 2k... my previous SS/TC did the same, seems like its a lil better since i got retuned last week, i was told by a few others its normal cuz of our cars being fuel injected... but thats just what ive been told.. id like to figure it out tho.. i mean i can deal with it.. its not that bad but it get annoying.. could just be the weather tho, everyday the heat index is like 105 here lol
Old Aug 4, 2011 | 07:22 PM
YelloEye's Avatar
Don't forget that if you reused your DI injectors you have to get all 4 seals and the seal adjuster kit so that they seal correctly.
Old Aug 4, 2011 | 08:16 PM
injector were already in the new head so they were never removed. what would the symptoms be of reusing the fuel pump bolts, gasket, and fuel pipe?
