Cat back question
Cat back question
I was under the impression that a catback does little performance wise (5 hp?).
Could someone then explain this statement from Modern Performance on their catback?
Introducing the MPx 3 inch Catback exhaust for the 2008-2010 Chevrolet Cobalt SS Turbo.
If you want a 3 inch, stainless steel catback exhaust that will connect to your factory downpipe or the MPx downpipe you've found the best option! Furthermore, we have dyno tested and seen a 12 horsepower gain with this exhaust with a relatively stock Cobalt SS Turbo!
Now the only *fly in the ointment* is>>>was this dyno WITH the MPxdownpipe added as well?
It doesn't *sound like it*.
They're saying the cobalt was *relatively stock*. I take that to mean mods would be maybe intake...but NOT a tune.
Turbo cars love as little back pressure as possible. The stock exhaust is 2.5in and probably really restrictive so it is possible to see that much gain from just an exhaust because of the .5in increase in size. Evos, Sti, and pretty much any turbo car sees a huge improvement with just an upgraded exhaust.
Almost everything I've read here ....."Don't bother with catback if you're looking for performance gains, the TC catback flows very well..." In fact, I was of the opinion..now I'm not so sure. If you are pushing 300 WHP and 21 lbs...is the stock catback restrictive at that point?
I might do that, but I'm only using my *ricer run* test for now..60-100 pull with a stop watch. I already have current results with the DP just added. I see Treadstone just came out with one that's around $499...Mpx is a bit less.
My question is then...with *supporting mods*...is it still ANOTHER 12 HP with the catback added? Or are they trying to pull a fast one and throw the catback in with gains attributed to other mods?
https://www.cobaltss.net/forums/4724699-post89.html
Verified 12 WHP with SC catback
Catback ONLY!
Can somone tell me WHY you would get this with an SC, but not our TC?
Was the exhaust on the SC THAT restrictive? This catback is only 2 1/4"!!! So it can't be much bigger than the stocker.
https://www.cobaltss.net/forums/dyno...results-32554/
10 HP gain on TC Catback
Agency claims verified 10 WHP (Mustang Dyno) with Catback alone:
Agency Power Catback Exhaust System Chevrolet Cobalt SS 08+
This exhaust system was tested on our Mustang Dyno and achieved approximately 10 horsepower gain. With horsepower also came improved throttle response, and low end torque gains. This exhaust is designed to work with the 2008 and up Chevy Cobalt SS sedan.
I see this is only a 2.5"....then again they say verified 10 HP. Could be 3" might not be needed with under 350WHP?
On a completely stock cobalt SS, changing the exhaust is only good for about 15hp max with no other changes.
If you have a cat delete downpipe, intake kit, and running 30psi boost, changing the stock exhaust would probably be good for 35hp. So it all depends on the set up.
~jason
~jason
I thought my muffler delete was good for 35 hp :P
No way that a catback would get you 35hp on the stock turbo.
When you get around 350whp and up, you need a 3" full exhaust to get any performance gains.
The catback exhaust is only good for maybe 5 "peak" hp gain. However, Im betting that they are suggesting that you can see as much as 12 hp gains in other areas of the power curve.
IMO. Go catless with muffler delete
Ronn, I had the MPx catted DP on for a while, and then added the Hahn exhaust. No noticeable change in power or spool. Just sound. 2.5" is what the stock system is, and it flows plenty for < 325 whp. You won't find any appreciable gains going to 3" with the stock turbo.
