CEL p0236 issue came back! HELP!!!
Old May 9, 2020 | 12:17 PM
TheVampyr's Avatar
About 2 months ago my car started to flutter and wouldn't go past 5 pounds. I assumed it was my bpv spring went bad or something and it wasn't the issue. So, i proceeded tp take off the bumper and check all the hoses for leaks and the coupler that connect the IC to the LC had a little net in it so i changed it. When i took the car for a ride i did not hear no flutter but car started to ramp into boost slowly. (car is nit tuned yet). Now, just last night after i filled up with gas the started driving weak and wouldn't go past 5 psi and i can hear the flutter. Any idea what it could be? maybe bad o rings on lower tmap or bad wiring?
Old May 13, 2020 | 10:00 PM
DeanSsspsh's Avatar
I had major p0236 issues for like 10 months. I changed everything to no avail. Turns out I had a failed pcv valve in the intake manifold. It wasn`t checking under boost so it created a vacuum leak. My problem was intermittent and the pcv valve was brand new. I cleaned my intake valves & installed a faulty pcv valve. I figured since the valve was new it wasn`t the problem. I was wrong & that was the last thing I expected. Drove me nuuuutzzz
Tristen Woodley
Mar 6, 2020 06:08 AM
nismopowerdqg
Sep 4, 2015 03:17 PM
nismopowerdqg
Aug 11, 2015 11:44 AM
1Shotwonder
Jun 28, 2015 10:07 AM
TheBoss8688
Mar 23, 2011 09:34 AM
