Changing launch control with HP Tuners
Is there a way to change the RPM of launch control with HP Tuners? If so where do I change it? I have looked around but I am not sure if I have the right spot or not. Thanks!
Why not?
I have the Hahn's BSR tune and it dropped from the 5100 to 4100 or so.
I'm still experimenting with getting the launch down with the extra power though. Definitely takes some finesse whatever way you decide.
actually it is an everyday function of an ecm... 2 step rev limiter.. hondata aem and numerous others utilize this... it is def an everyday function of an aftermarket ecm. i would like to see support for this asap especially because the stock is way to high unless you are running slicks with little tire pressure
We're not talking about aftermarket ecm's here, just oem one's.
The ppc tuner does add launch control to the lnf solstice/sky so there's definitely some code in there just for these features. Anyway your best best is to nag hptuners about this.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
