Changing launch control with HPT
It doesn't work quite the same as "launch control" but all you do is adjust the rev limiter for park/neutral. Just remember, as soon as you engage the clutch, that "limiter" doesn't work anymore...so if you've got it floored, once you engage the clutch, you're flooring it...which is why it doesn't really work the same as the launch control.
