CharGe Pipe question
Old Jul 4, 2014 | 10:08 AM
Louee29's Avatar
What is this hole for featured on one of my lower charge pipes?
Old Jul 4, 2014 | 10:15 AM
sam1031's Avatar
Vacuum line, and for the block off plate/map sensor
Old Jul 4, 2014 | 10:17 AM
slapbetcommissioner's Avatar
You don't need to make a new thread for the same thing again. Just bump your old one if you don't get your answer.
Old Jul 4, 2014 | 10:19 AM
Hard to tell by the size of that pic but I'm assuming the map sensor/ vaccume holes.
Old Jul 4, 2014 | 10:34 AM
Louee29's Avatar
So my stock one probably has the same holes eh?
this is my first thread about this bud
Old Jul 4, 2014 | 10:55 AM
Must be the second person today then.
Old Jul 4, 2014 | 02:15 PM
footballplaya3k's Avatar
This is correct.
Old Jul 5, 2014 | 01:55 PM
SSlobalt's Avatar
OP, here's a pic of the cold-side charge pipe with the 3-bar TMAP, but you get the idea. The stock sensor uses the two screw-holes, where the 3-bar that wasn't designed for our cars only uses the one hole.
This is where the vacuum line from the cold-side charge-pipe goes and why it goes there.
Old Jul 7, 2014 | 04:47 PM
Louee29's Avatar
Originally Posted by SSlobalt
OP, here's a pic of the cold-side charge pipe with the 3-bar TMAP, but you get the idea. The stock sensor uses the two screw-holes, where the 3-bar that wasn't designed for our cars only uses the one hole. This is where the vacuum line from the cold-side charge-pipe goes and why it goes there.
Thanks man.
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
