Check engine light after installing intercooler and charge piping
Old May 5, 2012 | 06:57 PM
b3mmster's Avatar
Looking for an idea on what could be causing a check engine light after installing a new intercooler and charge piping. I'm tuned with the HAHN PPC...yes a canned tune i know
Basically after installing everything now i check engine light. Tried returning the car to stock tune and retuning, also tried leaving the battery unhooked.
After leaving the battery disconnected the CEL went away on the first startup, but now on the second startup it's back.
I'm assuming there is a sensor that's probably going nuts somewhere as the piping or intercooler really wouldn't cause anything serious...but just wanted to check around to see if anyone has had this issue and what the fix was, it's bugging me.
Thanks!
Old May 5, 2012 | 07:02 PM
SSlobalt's Avatar
We need the code. Most likely a MAP code or a MAF code due to boost/vac leak. Did you replace the coldside pipe? Lower MAP plugged in? Vac hose next to lower MAP plugged in?
Old May 5, 2012 | 07:04 PM
b3mmster's Avatar
Yep coldside pipe is replaced, lower map and vac hose plugged in.
Doesn't seem like a leak, boost seems steady...but then again maybe it's too small to be able to tell.
Old May 5, 2012 | 07:11 PM
SSlobalt's Avatar
You have any way to read the code? Autozone?
Old May 6, 2012 | 01:30 AM
FasterIsBetter's Avatar
My coupler was cut with a 3/4" gash and I still had full boost at 24psi on the stock turbo. You could most definitely have a large leak and not notice it.
Old May 6, 2012 | 02:40 AM
TommyP's Avatar
AWD > FWD
Guaranteed boost leak. Probably a loose coupler. If you werent throwing a cel before, install some parts, and are suddenly throwing a code, 99% of the time it's the install/parts.
Old May 8, 2012 | 02:39 PM
b3mmster's Avatar
As it turns out it's P0100 which the code reader is picking up as mass airflow...I did adjust the intake so I guess that did it.
Does this most likely mean the sensor went bad? Or can I clear it and hope it doesn't come back?
I'm on an injen intake right now, I'm literally about to install a turboxs intake to match the intercooler and piping...
Old May 8, 2012 | 02:43 PM
damastah's Avatar
hmm.. could be the tune. i got a CEL when i get the injen CAI.
but if you are tuned for the injen CAI, and you go to a turbo XS intake you might throw a code because the turbo XS intake is much bigger in diameter.
stock tune the fuel trims were not off enough to throw a code. with the turbo xs intake.
have you thought about getting another tune?
Old May 8, 2012 | 09:02 PM
SSlobalt's Avatar
Nope. That's a boost leak. Unmetered air being pulled into the system via the leak shows up as a MAF code.
Old May 9, 2012 | 08:03 PM
b3mmster's Avatar
Good to know, i'll do this asap and post the results.
deviance
Nov 24, 2015 05:51 PM
Charmz_11b
Sep 13, 2015 10:54 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
jthwjde
Sep 7, 2015 09:24 AM
