Clutch problems
Old Apr 11, 2010 | 06:44 PM
Black_Turbo_SS's Avatar
Clutch problems
Ok so I switched engines and I need help with transmission. So does the clutch use a brake resovoir to bleed clutch?? And where would it be at. Bc when I hit my clutch pedal it just goes all the way down.
Old Apr 11, 2010 | 07:04 PM
Iam Broke's Avatar
Get a vacuum bleeder and use it on the brake master cyl, it's common to the clutch and the brakes. Draw 20-24" vac with a hand pump, hold until it stops bubbling, release vac, pump clutch 10 or so times, repeat until no more air bubbles and pedal is firm. Don't pump the pedal with vac applied.
Brake pedal will be low the first time after vac bleeding the system. Pump them up before driving.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
