Clutch Question!! Please Help!
Old Oct 10, 2012 | 07:12 PM
Savazquez's Avatar
Ok so had to do an engine rebuild since my piston ring number 2 blew which cause a hole in the piston. Had dropped the craddle removed the engine. Transmission stay on craddle. Reinstalled engine lifted craddle. But now my clutch has no pressure it stays at the bottom! If i bleed it with the vac pump it will gain pressure but is los after first pump and fluid leaks out of bottom of tranny. I checked distribution block but everything seem ok. Also while engine was removed I pressed the clutch by mistake, could this have caused damage!?
Old Oct 10, 2012 | 08:12 PM
tomj77's Avatar
dont know ur clutch answer, but how much boost were u running on ur stock turbo?
Old Oct 10, 2012 | 08:51 PM
Savazquez's Avatar
I was running 27 psi. But the damage on piston number is incredible. Looks like someone shot the piston.
Old Oct 10, 2012 | 11:09 PM
tomj77's Avatar
ya u cant run that much boost on stock turbo, it produces nothin but heat after about 23-24 psi. pretty much everyone who has run that much boost has had the same thing happen.
Old Oct 11, 2012 | 01:59 AM
FasterIsBetter's Avatar
Either you blew the seal on the slave cylinder from pumping it uncompressed(fluid had no where to go so I'm betting thats what happened) or you randomly blew the rubber seal on the clutch pipe at the distribution block and I highly doubt that. I would say 95% sure you blew the seal out of the slave cylinder so you have to pull the trans....
Old Oct 11, 2012 | 02:03 AM
BankerBalt's Avatar
did you put a new slave cylinder in? if not, there's your problem.
Old Oct 11, 2012 | 12:41 PM
SSlobalt's Avatar
+3 on the TOB seal being blown.
Old Oct 11, 2012 | 11:21 PM
Savazquez's Avatar
Thanks guys. I'll start pulling the tranny tomorrow but not looking forward to it. Is there a way to determine which is busted or will there prob be physical damage making it obvious?
Old Oct 12, 2012 | 08:16 PM
sebleroux08/tc's Avatar
i haate these pieces! aha if the TOB is blown there will be lots of fluid leaking from the bottom of the bell housing
Old Oct 13, 2012 | 12:54 PM
SSlobalt's Avatar
Just ask this guy about his experience with it, OP.
Old Oct 13, 2012 | 01:20 PM
^^^ how nice of you to remind me never making that mistake again ahah
Old Oct 13, 2012 | 01:22 PM
SSlobalt's Avatar
It wasn't your mistake, though. You received the wrong pressure plate, right?
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
SSLOW06
Oct 1, 2015 07:21 PM
