cobalt ss/tc vs procharge SRT-8 300c
A stock M5\M6 is around 428-430 whp= 500 crank.... You'd need 340+ whp to run an M6.....weight to power ratio might be lower for your car but that does not mean your car will be faster......
The turbo on our cars looses power when boost passes 27 lbs\psi... It's pointless to run your factory turbo like that, it'll not last more than a few thousand miles at this rate....
Pulled would mean the SRT8 was behind the cobalt and catching up!!! DUH!!... SRT8 in front from the start, Walking is more like it.....
The prochargers for these cars (SRT8's take them from 420 hp to 540 or so crank hp) , so he did keep up rather well considering this thing is 4100+ lbs and makes more hp at the crank than the 500hp M5\M6's in the world with the same weight.....Not bad......
camaromanss1992
Oct 1, 2015 10:51 PM
