Considering Upgrading to the LNF
Old Nov 2, 2012 | 11:48 AM
padlock's Avatar
that doesnt mean you dont have a gunk issue building up... my car runs fine as well with 53k on it, but I'm not saying its perfect by any means. I'm actually fairly scared to see how bad it might look and given your from canada (hence colder climate), that would be reason for you to be more concerned too as there has been some pretty nasty valves I've seen on DI motors up there
Old Nov 2, 2012 | 11:56 AM
user 72239's Avatar
If you care that much about it.
1. Buy new head
2.Install new head
3. take old head, and scrub intake valve stem's clean using a toothbrush or if you are lazy, sent off to clean
4 Wait till new head is bad, probably 2-3 years.
5. install old "Cleaned" head
6. ?????
7. Profit
Old Nov 2, 2012 | 12:11 PM
nobody2u's Avatar
Out here in NS we have the warmest winters in Canada. May be even as warm or maybe even warmer than yours since you live inland. I know in the lower Ontario region their winters can get pretty nasty.
Old Nov 2, 2012 | 01:30 PM
CobaltItaliano's Avatar
Yeah might have to see what Powell's fix does and how it keeps off the buildup. Everything else he makes works amazing so I'm sure this would'nt be anything different. I wish GM would have thought of this when the LNF was in production...
As my only option being buying a used LNF, the only option is walnut blasting the gunk off, then buying Powell's fix? (as the inexpensive option) Like I said before I don't have big plans for it, just simple bolt-ons and using it as A DD. Just gunna stick with premium gas and mobil 1 syn. oil and not going to e85/47 either.
Old Nov 2, 2012 | 02:23 PM
padlock's Avatar
you say that now... BUT with the power gain possibilities you will probably change your mind in time. Pretty sure almost all of us DD our SS's
I wouldnt be too worried about massive gunk issues.. i bought my ss with 40k on it in april, now 53k and I'm not concerned about the gunk being bad enough to hinder performance. I just dont want it getting worse than it likely is already. The gunk doesnt build up THAT quick. If you really concerned buy a boroscope and see what it looks like before you purchase
Old Nov 2, 2012 | 03:30 PM
nobody2u's Avatar
Haha this. I'd be running an E blend if it was available around here. Sadly there isn't any east of Montreal...
Old Nov 2, 2012 | 04:13 PM
lol. Yeah I'm not gunna lie reading on here about e85 and since I live in WI and theres a TON of stations with it I may eventually (may lol) go that route if I ever want more power.
However, like I said I'm very noob when it comes to the LNF and DI for that matter. So say I bought a LNF with around 40-50k miles on it and just keep up with regular maintenance like Mobil 1 synthetic at about 25% oil life. Will the gunk just eventually build up really bad it will cause any major damage? And if it will, what would it damage?
I've never used seafoam before either so that would be new to me if its needed to keep gunk from piling up.
Old Nov 2, 2012 | 06:19 PM
SSlobalt's Avatar
i highly doubt you'll find an LNF with the factory squeaking bastards on the rear.. but its just a matter of switching pads out if thats the case
I still have my stupid factory rear brakes in my '08. I only have 23K miles, though. The inner pads are almost down to metal and my rotors are chewed up. I need to fix that, soon.
Old Nov 2, 2012 | 06:28 PM
nobody2u's Avatar
Whether or not the valve gunk is a huge issue isn't certain, nor is the cure. Either way I have extended warranty so I'll just bitch at the dealer haha.
Old Nov 2, 2012 | 06:30 PM
Originally Posted by nobody2u
Whether or not the valve gunk is a huge issue or not isn't certain, nor is the cure. Either way I have extended warranty so I'll just bitch at the dealer haha.
hmmm maybe I'll just hold on and wait and see if any problems start to surface with it at all. I'd rather have something easy to maintain than having to worry about what my rpms are and spending almost $400 on something that should have been there from factory. Who knows though. All depends on when I get hired somwhere
Old Nov 2, 2012 | 07:29 PM
  #36
BlackLsCoupe's Avatar
I've never seafoamed and my car is perfect.
same here. 82k miles and runs fine. dealer did head gasket recently and they said mines clean as it would be new.
Old Nov 2, 2012 | 10:27 PM
  #37
Ltguy's Avatar
Originally Posted by Dart_SI
If you get an RPD youll never use your speedometer. lol
This^^^^^^
Old Nov 2, 2012 | 11:22 PM
  #38
reaper89's Avatar
Originally Posted by Ltguy
This^^^^^^
i 3rd this, since i put the boost gauge in, all i look at is the speedo on the rpd
I went from an LS to a LNF, and have not looked back. Its a good DD, and once your bolted and tuned, its a fun as hell DD
Old Nov 3, 2012 | 12:40 AM
  #39
007Balt's Avatar
I use my speedo on the rpd whenI'm doing traveling just to know if I'm near the speed limit or by how far away I am from the speed limit lol
Old Nov 3, 2012 | 12:55 AM
  #40
serega12's Avatar
Do it. Just get one. The gunk in the head... the heads are expendable, can't resurface them... new one is $400 with everything included if you're out of warranty...
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
HEATON
Oct 16, 2015 07:21 PM
Oct 13, 2015 09:32 PM
dieGone
Oct 1, 2015 06:27 PM
patooyee
Oct 1, 2015 01:07 PM
