Coolant temp
Old Sep 12, 2017 | 09:27 PM
Kickbutts228's Avatar
Coolant temp
So I have been noticing now that it is starting to get cold, at night that when I turn on the heat the car goes from 190 degrees to 200 degrees. Would it have anything to do with the ZFR 6758 turbo coolant line? I had the car for 2 weeks before I installed the zfr turbo so I have no clue if this was happening before. It's nothing I'm to conserned about just curious if this is happening to anyone else.
Old Sep 12, 2017 | 09:46 PM
Tdubbs's Avatar
Mine does the same thing. Usually hangs around 183* while cruising, but if I turn the heat on it runs up to 189* and stays there until it's turned off. Did it with stock turbo and now with the Z54. I think that's just normal for the vehicle.
