Dashhawk
Original Hayden Fanatic
Yo, anyone on here have the DashDaq? i put mine in and i'm trying to read the wideband, but it not reading right. In the above post you got your Dash Hawk to give you a wideband reading, what sensor were you using? Thanks
I have a Dashdaq. What are you trying to read? AFR?
Yes, I'm trying to read AFR, it just seems to make no sence and not sure what sensor to choose.
Yea, mine has two types or at least I think it does, Lambada(wide) and current (wide). How do I need to setup the gauge? I bough thing soley because I wanted to read AFR really.
I was doing the beta testing for the lnf ecm for msd, believe me i tried to get them to support iat2. But the head huncho of development was let go and they stopped updating the software. There were updates coming out almost every week when he was there, now software updates are basically dead on the dashhawk.
There's no oil pressure sensor on the lnf, only a switch that tells you that you have pressure.
The lambda(wide) is the wideband output, you just have to multiply it by 14.7 to get afr. If you have the latest firmware update, i think it ends with 1633, there's a rescale signal driver that allows you modify any pid however you want. Download the latest manual from here for the dashdaq and look on page 29 for more info, you can also get a boost readout by taking the map sensor and subtracting the barometric pressure sensor from it.
