Dejon Intake
Old Dec 8, 2009 | 12:27 PM
Terminator2's Avatar
Originally Posted by ClearImageAuto Dan
Charge piping first, then intake and tune at the same time so yo can data log.
I agree. Also if you want a DP get that right before you tune as well especially if you are getting a catless DP.
Old Dec 8, 2009 | 01:14 PM
Ferretts's Avatar
Originally Posted by Terminator2
You are making the assumption that all that have owned Dejon's intake and had issues with it are stupid. Bad assumption to make.
It is poorly designed. It has a piece of coupler inside a coupler as a reducer instead of a proper 3" X 2.5" reducer or what ever size it was. Because of the outside diameter of the coupler it hits the BPV cover before the coupler can slide all the way onto the turbo. The breather fitting does not reach and it has no barb to retain the stock breather hose even if it did reach.
First, i did not say all... I said most!
second, i cannot comment on the pcv provision as i just had it deleted and ran the check valve with a breather, the only company to offer that option and guess what, that works perfectly!
Old Dec 8, 2009 | 02:36 PM
Have you noticed that because of the OD of the "coupler" it hits the BPV cover before it slides all the way onto the turbo? Even if you tighten it relly well it can slide around on there because of that ghetto rigged coupler.
Old Dec 10, 2009 | 05:07 PM
cobaltltblue's Avatar
tI did have to trim my coupler to fit around the bolt on the BPV. Little bit of tweaking and it works perfict and it does not cost what a hahn costs. same reason i went with a 3" from mandrel bent instead of a kit that costs 2X as much. just bent the hangers a bit and it works fine and the end result is the same.
Old Dec 10, 2009 | 05:18 PM
Iam Broke's Avatar
Has anyone logged the Dejon SRI with HP Tuners? I couldn't log when I had one. If so, what was the LTFT skew?
Old Dec 11, 2009 | 11:41 AM
Ferretts's Avatar
I have, but it hasn't fallen off yet, and i have had my car to 160, gone off-roading, and have caught air at 80-90 mph, and hit a deer with the intake on unchanged since the day i installed it. If it falls off, then you must be doing something rediculous to the car because i for one, beat the **** out of my car.
I also have the charge piping with a crazy steve intercooler, and i have had some slight issues with boost leaks on the chrage piping, but i feel it is the crazy steve intercooler causeing the problems, so i need to give it a little tlc before i see whats what.
Old Dec 13, 2009 | 08:01 PM
Whtbolttc09's Avatar
I tried to install my intake last week. I'm no master mechanic but I can't get it to fit right. It is hitting my ac line. I can't even get the intake to line up porperly with the coupler. Any suggestions on what I'm doing wrong or what I need to do? Thanks
Old Dec 13, 2009 | 08:13 PM
slowbalt84's Avatar
you're an idiot, hope this helps
Old Dec 13, 2009 | 08:14 PM
Iam Broke's Avatar
When I had the Dejon SRI, I put split rubber tubing over the A/C line and zip tied it to one of the stock filter mount threaded studs pulling it over to keep it from rubbing on the intake. Also wrapped the breather connection with self sealing tape (Scotch 130C) to keep it from leaking.
It'll fit, but make sure the 'coupler reducer' is inserted in the end properly so it doesn't move after it's clamped onto the turbo.
Old Dec 13, 2009 | 08:35 PM
No not really but thanks for the useless input.
Old Dec 15, 2009 | 10:26 AM
  #36
Mine was off about -11 LTFT, after i tuned it out now i'm .4 off. Still loving mine. I also got the Spring, and I love the sound. I used a blue Spectra cone filter because it matches my car and it's a dry filter.
Old Dec 15, 2009 | 10:43 AM
  #37
You are a useless miserable little POS. GTFO unless you have something constructive to say you moron.
Old Dec 15, 2009 | 10:49 AM
  #38
Shez's Avatar
He always says something stupid in every thread I've seen him post in. He's trying to be funny but he's not doing a good job and just making himself look like a dick. : /
Old Dec 15, 2009 | 11:07 AM
  #39
I am not sure why he bothers. He is not funny at all. Just another assclown.
Old Dec 15, 2009 | 11:19 AM
  #40
padlock's Avatar
Originally Posted by wantedSS/TC
Airbox Mod w/ KN drop in. Done.
x2!!
Old Dec 15, 2009 | 11:20 AM
  #41
Gestapo007's Avatar
i believe i stated this in another thread, i think he places a cucumber on his chair so whenever he sits to go on the computer he has something crammed up his ass
Old Dec 15, 2009 | 11:21 AM
  #42
Sounds about right.
Old Dec 15, 2009 | 01:38 PM
  #43
80vetteL82's Avatar
+10000000 Ive noticed that in every thread hes in too.
Old Aug 1, 2010 | 08:30 PM
  #44
CatchMeIFyouCAN's Avatar
whats the part number for that pcv connector ... please
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
OrangeCoba
Sep 25, 2015 06:06 PM
