Dejon Intake Install Help ASAP!
Old May 12, 2009 | 04:00 PM
Projekt's Avatar
oKAY I removed the stock intake..well putting on the dejon intake i took those two black coupler peices off of the intake itself...the one smaller sized one can not fit back onto the intake..so i placed it on the turbo the bigger peice fits snug over the intake..so can i not just fit the bigger peice over the smaller piece and use the clamps to secure it???
i need help...ill take pics and upload them asap
its 2:50 at 3:30 i need to go pick my girlfriend up lol
bump pics uploading now
bump bump bump!!@!
Old May 12, 2009 | 04:03 PM
crypticscifer's Avatar
FYI. It apears you have the upgraded spring as well. B4 you put the intake on unscrew those 3 bolts to the tan cover (use the sicket that angles) and be carefull you dont loose the stock spring, pull the whole unit out of your turbo, separate carefully the black and tan pieces put your new spring in and apply force inwards when tightening.
Step 1. Put everything back as it came shipped. (you need all the parts)
Step 2. tighten the clamp on the side of the coupler (rubber hose) the is toward the filter completely, if not already from factory.
Step 3. keep the other clamp very loose, then adjust the intake until it is almost flush with the turbo housing and rises over your A/C line in the bend its ok if it looks high it will close if right.
Step 4. tighten that last clamp down all the way.
Step 5 attach your vaccum hose to the stock one put your filter on and thats it.
Old May 12, 2009 | 04:07 PM
Projekt's Avatar
okay, thanks my question is does the smaller coupler go on the turbo or the intake pipe..becuase i cant for the life of me get it back onto the intake pipe
Old May 12, 2009 | 04:13 PM
Terminator2's Avatar
The smaller side of the coupler goes onto the turbo. The larger side goes onto the intake pipe itself.
Best bet is to put it on the intake pipe it fits inside and acts as a shim, it might be molded already from being tigheted from Dejon so see where it fits best, it might not be completely flush, but it will be very close. Just make sure you tighten the clamp down and if the intake hits anything on your A/C line you could have issues, make sure if it touches its only the black cap, if you need to move the A/C line slightely that can work also as i have done it.
So the length of the coupler should be as long as the large one. Not extended as you have in your picture.
Old May 12, 2009 | 04:21 PM
Projekt's Avatar
well the larger one is exteneded because it fits on the intake pipe and is ment to go over the smaller coupler on the turbo itself..then clamp down for a tight fit am i right?
Old May 12, 2009 | 04:33 PM
Gestapo007's Avatar
with your intake in your hand, put the large coupler on. dont put it all the way down on the intake, keave about 2 inches off. now put the smaller one inside till it stops and hits the intake tube and connot slide in any further. now push the intake onto your turbo. secure clamps
Old May 12, 2009 | 04:36 PM
Projekt's Avatar
thanks man
was re-installing the new spring a two man job for anyone else..i cant seem to secure the bolts on well holding that strong ass spring down.
Old May 12, 2009 | 04:37 PM
thanks man
you need your wheaties.
just while holding it down with one hand, hand tighten the screws back
then you can re-center your grip and fully tighten, make sure no black is hanging out.
Old May 12, 2009 | 04:38 PM
Projekt's Avatar
your saying my little girly hands dont help in this situation
Old May 12, 2009 | 04:42 PM
uh not at all I have small hands and they were a benefit.
Projekt's Avatar
so do i ..like super small hands..but i cant seem to get the bolts on ****
Old May 12, 2009 | 04:43 PM
Then they are going in crooked, make sure all is flush ( push finger near center of cap) and aligned they can be started by hand only like 5 or so turns
Old May 12, 2009 | 04:46 PM
p_hanson's Avatar
PS...you're late!
GL!
Old May 12, 2009 | 05:00 PM
Projekt's Avatar
shes walking home sigh
yeah i had the tan peice on crocked..
now for the intake itself..FUN
Old May 12, 2009 | 05:16 PM
Are you still doing this it's a 20 minute job with taking the stocks out..
Old May 12, 2009 | 05:19 PM
Projekt's Avatar
okay intakes in..uploading pics..tell me what you guys think of the positioning
im just making sure i do everything right.
and taking alot of breaks.
No worries just breaking your *****.
Yup looks good, just rotate it a little forward, make sure it clears over that A/C line and as for the stock post you can do two things. 1 Bend it all the way down... i didn't like that or you can bend slightly away of your inatke is tight and 2 you put a rubber cap on that post you'll be ok otherwise yeah bend it further so you dont create a hole.
Old May 12, 2009 | 05:21 PM
Gestapo007's Avatar
intake is on good, but make sure that right clamp is securely holding the intake on the turbo. wiggle it a bit and if it moves alot make it tighter. may need to move that clamp to the right more. othen than that your good to go.
Old May 12, 2009 | 05:27 PM
duke_88_04's Avatar
haha was the GF pissed she had to walk home?
Old May 12, 2009 | 05:32 PM
Projekt's Avatar
not really.
also..i tighten it down as much as it can go..and i can still pull the intake right off the turbo...WTF
Old May 12, 2009 | 05:39 PM
steddy2112's Avatar
Waste of monies.
Old May 12, 2009 | 05:54 PM
Projekt's Avatar
okay so i put the small couplre over the turbo...then the large one over the small one..tigthen it done..put the intake pipe into the large coupler thats holding down the smaller coupler on the turbo..i tigthen that down..i give it a wiggle..a little wiggly but i cant seem to pull it out.
i put the maf/oil feed back in...the filter on..give the intake a snug pull..pops right off the ******* turbo again.
why is such a simple task putting up such a fight..****
Old May 12, 2009 | 06:17 PM
Gestapo007's Avatar
do u know why, cause listen carefully.
you have 2 clamps. the left clamp holds the coupler to the intake. put that clamp to the far left of the coupler. tighten the **** out of it till your arm hurts B4 you put intake on car. now put intake on car. SNUG! push it in and wiggle it in as far as it can go. now take other clamp and put it as far to the right of the coupler as it can go, to make sure your tightening it onto the turbo and not tightening nothing. now tighten the hell out of it.
if you cannot succeed at this, then stop modifying your car please. this is a simple task. how to connect pipe A to pipe B.
Old May 12, 2009 | 06:21 PM
Projekt's Avatar
yeah i understand this..i just have horrible tools...a big flat head with no handel lol.
my buddy is coming over with proper tools..should be easy enough then. thanks for the help.
