devils own stage 2 wiring help
Old Nov 5, 2011 | 12:03 PM
eqaddictedfool's Avatar
Hey guys so I'm relativly new to the whole modding scene as many are. Ive googled the hell out of this question but cant find anything specific. I have everything from the kit all set up except for the wiring. My questions are this.
The orange wire from the controller says it goes to the battery. Is there a wire that runs to the battery already or do i really need to run that sucker to the trunk.
The red wire from the pump runs to a fuse now im Assuming on the passanges side in the car since there doesnt seem to be an open spot for the fuse under the hood.
and which sensor does the green wire run to? Will it matter that i have the GMS1 set up?
Thanks in advance guys
Old Nov 5, 2011 | 02:55 PM
ok I have answered a few of my own questions on this. The green wire seems to run to the 3rd slot of the new gms1 sensor.
Turns out i had a fuse holder in the packaging. who knew!
Old Nov 5, 2011 | 02:58 PM
SSlobalt's Avatar
Whenever instructions say to run a power wire from the battery, they just mean you need to find a constant voltage source. You should be able to find a constant power source at the fuseblock under the steering wheel. Just use a test-light ($5 at autozone) to find a constant power source.
DarrenGC
Dec 24, 2021 01:55 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
jmelton327
Sep 26, 2015 10:04 PM
