Different Intercoolers?
Well i have seen different intercoolers out.
Crazy Steve has one for 250 that fits out cars....
http://www.genuinesaab.com/catalog/p...roducts_id=648
This one catches my eye.
What do you guys think? If we get full bolt ons. Is an upgraded intercoolers needed or prefered?
I know Hahn and Dejon have one and i wanted to get some input on all of them!
I haven't seen Crazy Steve's talked about much on this forum (maybe because he ain't a sponsor?), but other forums seem to sing his praises. Think if you plan to upgrade to a big turbo, you might want something better. But, for a full bolt-on car, Steve's would be the just the ticket. His shop is within driving distance of me (Springfield, MO) and he's supposed to be working on charge pipes too. If I were to invest in a better IC, this is probably the one I'd probably get, especially if he makes cheap charge piping to match.
If you're pushing the limits of the K04 and spinning it way out of it's efficiency range it might be beneficial to upgrade the intercooler, but then again I haven't seen any testing of how well the stock unit performs and then compared to an aftermarket unit. The stock front mount has a nice amount of surface area and the tube-and-fin core should benefit overall flow. I don't see the K04 out-flowing the stock unit, but I can't say for certain. Before I'd cough up money on an upgraded one I'd measure the inlet and outlet temps and pressure drop across the stock unit and see how it looks.
Many people just buy them because they "think" it's better or needed but few people seem to test to see if that's the case. There's nothing wrong with buying one just to say you have one, but it might not perform any better and possibly worse.
there is no camparison from my stocker to my hahn
the stocker looks SOOOO small and wimpy side by side to the hahn, plus the end tanks are pressed on plastic crap
I think an IC is a very worthwhile upgrade if you have a tune
stock, prob not
stock, prob not
Something that just came to mind:
Has anybody ever installed intercooler sprayers like on the turbo toys NSRT4s? Is there even any performance to be had with a setup like that? I can't imagine it'd be too hard to install if there was.. you could probably even use the windshield washer fluid reservoir as your fluid source lol..
When I get one ill be getting crazy steves ic. It fits just fine you just have to bend a couple AC brackets. I mean Steve with a bsr tune ic pipind and full exhaust ran a low 13 quarter. I don't think it drops any psi. But yeah that's my choice. I won't pay hahn 800
Most shops just buy the cores and weld on endtanks.
I am deffinatly gonna be picking this up... i wonder if there is any way that i can speak with someone about the product...250? i wanna see if we can get a Group buy!
not this again, intercooler if made right are not a you get what u pay for, there are loads of DSM's and subarus that have proven that already, they run the CXracing intercooler up to 400+whp levels and they hold fine
Compare the pressure and temp drop of a cheap core to a quality core and you will see what im talking about, you get what you pay for. There was a nice write up on the srt4 forums comparing around 8 different cores, they had them on the dyno and recorded the pressure and temp drops. The cheap cores made the least horsepower, had the highest pressure drop and the lowest temp drop, facts are facts.
exactly, 250 is not cheap for a intercooler, 100shipped is cheap, but 250 is very reasonable, hahns cost is way the hell out there, yes they get props for hitting the market first, but once the competition comes in, its a fight for the customers money, whoever can get a good product for cheaper will win
There's a few things to keep in mind about the "Turbo Toys" version of the Mopar Performance SRT-4 Stage 2/3 kits. If you tried to replicate the hardware it would not be cheap. Mopar used some nice Aquamist nozzles, filter, and fittings in their kit as well as a secondary water pump. Unfortunately if you aren't extremely careful in putting it together, it will leak like a sieve. The "toys" kits also used a different PCM (powertrain controller) than the non-toys kits that utilized custom programming to take advantage of an integral automatic transmission controller (which wouldn't be needed on the manual-only SRT-4) to automatically control the intercooler sprayer. If you built your own system you'd have to manually control the sprayers or possibly try to set up a thermistor (temp sensor) and relay setup to turn on a pump.
On the Neon, even when everything goes right it helps only a little at preventing extreme heat soak and doesn't cool the charge temsp as much as you'd think. It's also illegal at many track events due to dripping fluid on the track surface. Combine that with the cost to do a system right on a car like the Cobalt and you'd probably be better server with a larger intercooler. That wasn't an option on the Neon due to the front bumper support/cross-member limiting the intercooler size. Mopar did the sprayer since on Stage 2 with the stock turbo they were spinning it pretty high and creating a lot of heat and high intake charge temps where the sprayers could help the car run a little more consistent.
To tide us over, I found some quotes from Steve. Looks like he did put some thought into designing his IC. Sounds like from his tests, you can expect a 2-5 degree drop in temps and a little better spool up. He also says the stock IC flows surprisely well for stock.
If I were to do a big turbo swap or going for max performance possible, then I'd probably bite the bullet go with the best IC possible (like the Hahn or similar). But with a bolt-on car with possibly a wheel upgrade, why break the bank when you can get a better than stock IC at a lot cheaper price.
The core itself is 24x12x3....The core would/can handle 650+ seen the same core used on several boosted LS motors 550-850hp (dynoed at our shop). I Looked a lot into making this IC and learned a bit too, its better to have a taller shorter core than the other way and its better to have the core not too thick (ie not over 3" is what I have read) this all of course depends on were you have room the in-outlets are 2.5" so it will fit the stock hoses.
Little insite on our IC.....I will not try to sale you guys the moon and the stars....We tested a bunch on our dyno and you are not going to see huge gains changing the stock IC it is a great stock unit surprisingly. I did see better spool up (less restrictive) and a 2-5 degree drop, you also loose the fancy plastic end tanks every one wants
Whatever, its your money. If you want a cheap made in china intercooler than go right ahead, might i suggest the $250 turbos from ebay also. i believe they're glued together...
This is one of the reasons everything is being outsourced, you dont want to pay for quality parts so you buy the cheap crap from china.
