dissapointing dyno
dissapointing dyno
I got dyoned just now...super dissapointed 302/324...I have intake, dp, intercooler, byt tune.
Just wanted a baseline before the zfr... ill post the chart and vids when I get home
iv heard alot of bad stuff about byt so maybe they was more power left in the tune that u could still access for a retune but if u about to go with a new turbo I dont see a point. Also as it was said any dyno can be low or high.
Either the tune stinks or you have a low reading dyno. After the zfr with a good tune @ 24psi +, you should be into the 400's with 93 gas, if not, then you will know its the dyno reading low.
This time last year I got byt tuned, he is impossible . Find im having old school tune the zfr when I get it next month. I feel like it shouldve been faster
It could be a low dyno. Are you happy with the power level despite what you think are low numbers? IMHO those are pretty damn good numbers for a limited amount of boltons as long as the power is safe! And the ZFR is not a bolt on 400 WHP turbo without meth or E47/85 as if it was there would be plenty of pump gas only ZFR dynos showing that but they just dont exist!
My 1/4 mile time is great..still mad about the dyno..zfr should fix that...as my buddy said tho..I smoke a lot of cars and that dyno numbers will make people feel even worse
True. But still those numbers with that turbo? I'd be livid if i spent that money and got those results. I have more then that and I'm stock ko4.. Something does not sound right.... In fact most tuned lnf's are over 300 with minor bolt ons..
To the OP - Don't get hung up on Dyno numbers, if you want I have a friend that can make your car read 800whp on a Dyno. You should run friends that are around the same power range. Like others said ZFR = Sex. Keep traction you won't win a race spinning.
My 22 psi trifecta tune, charge pipes, inter cooler, k&n intake, forge bpv, catless down pipe, full exhaust only netted 305whp 325wtq wasn't impressed. Currently working on HP tune, I can feel the power difference no changes but the tune I'm going to dyno again soon
