Downpipe gasket question
Old Oct 12, 2012 | 01:20 PM
Bluekid99's Avatar
I'm picking up a Hahn 3 in Downpipe tomorrow and I was wondering if I can use the factory gaskets or if I need to buy 3 inch gaskets...can anyone help me out
Old Oct 12, 2012 | 02:47 PM
silverSS08's Avatar
As far as I know you just reuse your factory gaskets. It is a factory replacment part. If your gasket aren't in good shape that's another story. Also I was told there is no gasket between the turbo and the downpipe only between the exhaust and the downpipe is there a gasket.
Old Oct 12, 2012 | 02:48 PM
Wangspeed's Avatar
There are gaskets on both ends, of course, but most people reuse them. Generally that is okay, but there's a chance it will leak. I think mine are starting to leak since I've swapped the downpipe a few times now.
Old Oct 12, 2012 | 03:36 PM
silverSS08's Avatar
I'm buying a zzp downpipe from mkurley and he told me that he only has a gasket on the exhaust side and that there was no gasket on the turbo side. wangspeed so what your saying is that my current stock downpipe has a gasket on both ends and I will reuse those gaskets when I install the zzp pipe
Old Oct 12, 2012 | 04:35 PM
Wangspeed's Avatar
The turbo side gasket typically stays stuck to the O2 housing off the turbo. You usually need a pick to release it.
Old Oct 12, 2012 | 04:36 PM
Bluekid99's Avatar
So basically the same size gaskets are used even though its a aftermarket catless Downpipe? But probably better off using new gaskets just to be safe
Old Oct 12, 2012 | 04:47 PM
silverSS08's Avatar
Might be a dumb question but do I need to remove it with a screw driver or can it just stay there since I'm reusing it. For example does the gasket have to be placed on the dp before instalation or can it stay on the turbo during installation.
Old Oct 12, 2012 | 04:56 PM
Wangspeed's Avatar
Most people just leave it alone, but it can leak, since it's a crush gasket.
Old Oct 12, 2012 | 05:00 PM
silverSS08's Avatar
Ok thanks a lot. And op sorry for the thread jack.
Old Oct 12, 2012 | 05:02 PM
silverSS08's Avatar
If you want to spend the money on the gaskets and want peace of mind than yes buy the gaskets. But as wang said most people have reused the stock gaskets without any problems, though there is a possibilty of it leaking
Old Oct 12, 2012 | 09:24 PM
Bluekid99's Avatar
Alright thanks
brandon04
Oct 21, 2015 07:04 AM
no_ss
Oct 18, 2015 11:58 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
