Downpipe installation questions
Old Apr 5, 2012 | 04:12 PM
malachii's Avatar
Hi guys,
Just purchased a second hand ZZP catted downpipe, and I'm looking to install it this weekend. I've never done it before, but I don't imagine it's too tough. I'm planning to use jack stands. I don't have any gaskets. Will I need new ones for this, and if so, how many, and are they a generic product I can buy, or do I need to buy them at the dealer? Lastly - any specific torques I should use, and any gotchas?
Thanks!
Mal.
Old Apr 5, 2012 | 04:23 PM
jvirginillo's Avatar
Take the old gasket to a auto parts center and purchase the best gasket they have because some of the cheap ones then to 'blow out' if things are not fitting tight.
DO NOT!! Lift the down pipe up to the manifold from above the engine or you may crack the flex tube portion. Handle the flex section with care, they are not as tough as you might think. Get under the car and push the pipe up to the manifold.
Old Apr 5, 2012 | 04:24 PM
JBThrasher22's Avatar
https://www.cobaltss.net/forums/how-...g-pics-160726/
Enjoy
Old Apr 5, 2012 | 04:37 PM
^^^ Now that is a response!! Nice!!
Old Apr 5, 2012 | 04:44 PM
SSlobalt's Avatar
The only thing I would change from that How-to is to leave the O2 sensor in the pipe. Just unwrap the O2 sensor wiring from the heatshield and uplug it from the connector, then leave it in the pipe. It is much easier to remove and install the O2 sensor when the downpipe is out of the car. It will keep you from twisting the wiring, which can break it.
You can reach it from the driver-side fender-well.
Old Apr 5, 2012 | 04:52 PM
ssyellow's Avatar
Orange RTV does wonders at making gaskets. I think its called copper or something? Not sure but I have it at my house.
Old Apr 5, 2012 | 04:58 PM
alerosaint's Avatar
I co-sign on this...makes it sooo much easier
Old Apr 5, 2012 | 07:08 PM
malachii's Avatar
Thanks for the awesome info guys! Also, is there only 1 gasket, or 2 that I need to purchase?
Old Apr 5, 2012 | 07:11 PM
SSlobalt's Avatar
Just the one in the manifold. For my '08, it was this part:
Old Apr 5, 2012 | 07:19 PM
malachii's Avatar
Wow, even with a part number - nice! Thanks. What kind of gasket is this anyhow? In my admittedly limited amount of work on cars I haven't run into this type yet. Just head gaskets and the like.
Mal.
Old Apr 5, 2012 | 07:21 PM
SSlobalt's Avatar
It's sort of a crush-gasket. It just clearance-fits inside the exhaust manifold coming off the turbo.
Old Apr 5, 2012 | 07:29 PM
ssyellow's Avatar
I was just going to ask if it was a crush-gasket. I didn't change mine out when I did my down pipe install and had no problems.
Old Apr 6, 2012 | 12:57 PM
SSlobalt's Avatar
You don't absolutely have to change it. It's just for piece of mind. An exhaust leak can cause codes.
Old Apr 6, 2012 | 01:07 PM
Wangspeed's Avatar
I prefer to remove or at least break the O2 sensor loose while it is supported. Breaking it loose when the DP is off the car sucks.
I've never had a problem doing it with the pipe on the car, but I make sure to pre-twist the harness before putting it back on.
Oh, and if you have a (real) flex socket, with a locking 2 foot extension, life will be much easier.
Old Apr 6, 2012 | 04:31 PM
rogersj's Avatar
i reused my gaskets with no problems
Old Apr 6, 2012 | 08:17 PM
SSlobalt's Avatar
I don't like twisting wires.
Old Apr 6, 2012 | 11:03 PM
Skept1kal's Avatar
Enjoy your new beast when u get in installed. I just put my ZZP catless on 2 days ago and im blown away by it. Great part!
Old Apr 7, 2012 | 04:21 AM
nRRe's Avatar
hoping to do mine this sunday...can't wait.
Old Apr 7, 2012 | 02:39 PM
krispy's Avatar
I tried doing mine today but goddamn are the nuts stubborn as ****. I got the 2 going to the catback loose and one on the turbo flange and it took a **** ton of torching and a ton of force to even manage that. Gave up when on one of the upper turbo side ones I half rounded off a nut.
I even had presoaked all the nuts over the last few days with pbblaster in anticipation. Debating what to do next...pay exhaust shop to break em loose? Get electric impact? More propane? Get MAP torch? Decisions....
60k miles and 3 winters were not kind to the fasteners
Old Apr 8, 2012 | 12:09 AM
SSlobalt's Avatar
That many miles is going to make it tough. You can always drive it around for a while, then try to loosen them without burning your self. I impacted mine off, but that's risky.
Old Apr 8, 2012 | 12:52 AM
Sox-Fan's Avatar
Got Brakes?
Had to propane mine. 47k. Get em cherry red and they turn ok.
Old Apr 8, 2012 | 01:50 AM
nRRe's Avatar
this isn't what i want to hear, lol.
i havent pb blasted anything in advance but i only have 34k miles on my car...
Old Apr 8, 2012 | 10:11 AM
09TcSedan's Avatar
its usually a biatch getting the O2. when i took the Hahn DP off my buddies TC. we pre soaked it with WD40 and took a huge wrench and got it off. wasnt too bad but it is a biatch to get off
Old Apr 8, 2012 | 10:26 AM
Wangspeed's Avatar
The O2 is cake, if you have an O2 socket. I use a crow's foot version.
The nuts on the upper flange can be tough. I use a Snap On cordless impact and it handles them with ease.
Old Apr 8, 2012 | 02:23 PM
krispy's Avatar
My o2 socket was too long to fit, I just heated the area around the threads a lot and then tapped the 22mm wrench with a hammer til it broke free.
I got the 3 cat-back nuts and 2 of the 4 manifold nuts broken free....the others (top 2 on the manifold) would not move even with a dozen or so propane/PB blaster cycles. I destroyed one completely...first with the 15mm scoket, then with the 15mm bolt out...then tried hammering on smaller sockets/bolt outs with absolutely no success. I now have a nicely tapered smooth rod as a nut....I'm not sure what else to do short of notching it with dremel and using chisel/hammer. At this point I'm just going to take it to exhaust shop and have them break free/replace the 2 I can't get loose. Probably should have gotten a MAPP torch...
Anyone know what the thread size/pitch is? M10x1.5?
