Dp ?
Dp ?
I know alot of people have changed their downpipes. Anyone care to tell me what size the nuts/bolts are? If you don't mind, how many extensions did you use? I cant find my deep wells or extensions so I'm gonna have to buy new ones, that's the reason for such a lazy sounding question.
it's funny you asked because i had to change over my catless downpipe to my factory one today for an inspection. And then after the inspection i came home and put the catles back on. I can do it in like 5 minutes flat now lol.
15mm it is. A long extension helps, but if you just undo where it couples to the rear section first, you can bend it down slightly and it makes some room for you
Should take no more then an hr!
yah im thinkin of getting a Catess cause the ca isnt loud at all... i dont want obnoxiously loud but im sure it wont be like that if i get catless hell might even gain a few horses
jeezes changing DP's is a pain in the ass. had to take the catback hangers off to let the catback hang so i could get to the top bolt on that 3rd bolt flange. and the extensions for the turbo suck. Only had enough extensions for a 3/8" ratchet, but went out and bought a 1/2" -3/8" adapter so i have more leverage getting those nuts loose. changed 2x so far, after my inspection i gtotta do it again lol.
Just pull down on the exhaust a bit and you can get to that top bolt pretty easy. I used a deep socket with no extension and got it off without too much effort or aggrivation.
I just bought a metric set of deepwells at harbor freight for like $10- they're tools are so damn cheap! So whether mine are 15mm or 17mm I'll be set. Thanks for the info everyone.
