DP...Hahn VS. CIA VS. ZZP
Old Jun 1, 2009 | 09:20 PM
marcusicp's Avatar
Originally Posted by ColeJJones
synapse....
Why? So you can pay more for the same stuff?
Old Jun 1, 2009 | 09:23 PM
1badBlueberrySC's Avatar
It took me and a buddy and a lift... about 20 minutes (if I wouldn't have stripped the stud) luckily my buddies shop had one there so we just put it back in.
And yes there is a "BIG" change!
Old Jun 1, 2009 | 09:44 PM
purplehaze03's Avatar
question if you throw a code (cel) is the car drivable? will it cause issues?
bump?
Last edited by purplehaze03; Jun 1, 2009 at 09:44 PM. Reason: Automerged Doublepost
Old Jun 1, 2009 | 09:45 PM
Depends on the code... if you throw an o2 code it could cause... lean or rich conditions making your car run... but not well.
Do yourself a favor get the angled bung... or get a cat (if you aren't tuned)....
Old Jun 1, 2009 | 10:09 PM
i am going to get tuned, i have the hahn cold air intake, muffler delete, dejon bpv spring upgrade, and just ordered the adm downpipe, but dont want to get tuned until i get my charge piping! to get the most out of my mods, unless someone on here knows how to tune me for charge piping id just have to be easy until i get it
Old Jun 1, 2009 | 10:19 PM
fredds-turbaltSS's Avatar
^If you didn't want to wait i doubt the IC piping would affect the tune much
Old Jun 1, 2009 | 10:40 PM
i just wanted to get the ic piping first because my factory piping popped off already (i fixed it ) but i have noticed that at higher rpms the stock hot side of the piping has alot of flex, i really want to do it right looking for 325whp maybe a little more is it dooable on factory piping
bump?
Last edited by purplehaze03; Jun 1, 2009 at 10:40 PM. Reason: Automerged Doublepost
Old Jun 2, 2009 | 12:03 AM
redstarpa69's Avatar
DO NOT STRETCH THE O2 SENSOR/WIRING - if you did - you could and will strip the wiring from the sensor, that's because the motor will move back and forth, its happen to a few guys already, that's why most guys returned the CIA & ZZP DP's.. that plus CEL kept coming on even if CEL got tuned out..
Originally Posted by fredds-turbaltSS
tight wires are also no big deal, i no how to cut splice and solder..have trouble spelling sometimes thought haha
if you cut the O2 wire - get ready to buy another one.. that wire is super sensitive if cut..
Last edited by redstarpa69; Jun 2, 2009 at 12:03 AM. Reason: Automerged Doublepost
Old Jun 2, 2009 | 12:05 AM
WOW dude, you need to relax. It's not STRETCHED it's mainly MOVED!
Old Jun 2, 2009 | 12:13 AM
DJAudio's Avatar
Originally Posted by sponge14
The way the O2 sensors are located in the exhaust stream in the CIA will prevent you from throwing any CEL codes.
I vote for CIA! Their quality is really great. However I did throw a no cat code. Thanks normal tho I think till I get a tune done.
Old Jun 2, 2009 | 12:22 AM
  #36
Gestapo007's Avatar
yo, what do you do about inspection. your in the same state as me. Just swap em out.
Old Jun 2, 2009 | 07:20 AM
  #37
i plan on just swapping for inspection......
Old Jun 2, 2009 | 07:54 AM
  #38
bump?
anyone know?
Old Jun 2, 2009 | 09:23 AM
  #39
Mazdaboi318's Avatar
Get the piping from CIA....much more sturdy and will hold 325 easy!
Old Jun 2, 2009 | 10:40 AM
  #40
im waiting on my IC piping but im tuned now holden 20 psi in the stock piping, no problems yets its been over 2 months..
Old Jun 2, 2009 | 10:57 AM
  #41
i have stock piping on mine right now... 22psi without any issues been tuned since 1400 miles!
I have dejons piping coming today though... we'll see how well I like it!
Old Jun 2, 2009 | 11:14 AM
  #42
Terminator2's Avatar
I blew a hole in my stock piping on the rubber hose near the turbo after 6000 miles only 1000 of which were tuned at 20-21 psi.
Old Jun 2, 2009 | 11:36 AM
  #43
Gestapo007's Avatar
Good choice. I love Dejon, Dave always replies to my email's in hours, not days. And there product speaks for itself.
Old Jun 2, 2009 | 12:04 PM
  #44
reign1's Avatar
ok man.
so ur going to try and save money.
I would advise on the catless DP from CIA. its bent when you order it. the welds are amazing. and everything lines up.
Running staight pipes on catless sounds like garbage. really ricey.
Dont use the dejon BPV spring. this has been discussed many times.
took me half hour with jack stands to take out the DP and put the CIA one on.
The o2 sensor lines right up. no Codes. no problems whats so ever.
and as far as IC piping go. it is honestly a great way to go.
Im doing CIA piping as well. the performance not the dress up. 30% less piping and a lot better airlflow...
when you get tuned. tell ur tuner that ur getting or have CP. they have to raise ur rev limiter for the CP.
Old Jun 2, 2009 | 04:06 PM
  #45
Originally Posted by reign1
ok man.
Have you actually ever HEARD a catless D/P on a stock catback car.... It sounds ******* good as hell... NO RASPY, just a deep grumble on THROTTLE!
CIA... was my first choice but they told me they wouldn't split up the hot and cold side pipes so I went with a company that would!
If I decide I don't like these... I will swap them out and get the CIA pipes!
Don't be a brand nutswinger, I buy parts for a reason... not hap hazard!
I also have the Dejon spring... once again NO ISSUES after 3000 miles!
Old Jun 2, 2009 | 04:19 PM
  #46
Yeah, i have the Hahn CAI, CIA IC Piping and i just ordered my ZZP DP. CIA turned me off simply bc iv been waiting for over 2 months since the GB has ended for my IC Piping
Old Jun 2, 2009 | 04:22 PM
  #47
CIA's charge pipes are nice... I like them alot. But I however have a guy that is doing my cold side pipes for basically nothing...
so all I wanted was hotside... plus I wanted red!
Old Jun 2, 2009 | 04:40 PM
  #48
I took my dejon spring out because I was seeing some flutter when letting off the throttle, and few have had issues with burnt out BPV solenoids. I thought better safe than sorry in this case. I think the stock exhaust with a Catless DP sounds pretty good but I like the way mine is now a lot better. When I first got my Catback It was kinda raspy and popped back some but it sounds better now as the muffler has broken in.
Old Jun 2, 2009 | 04:46 PM
  #49
Talk to Dan about this please!
Old Jun 2, 2009 | 05:06 PM
  #50
Hey got the best tune now boy! WOOT
