DP...Hahn VS. CIA VS. ZZP
Old Jun 2, 2009 | 05:26 PM
  #51
reign1's Avatar
blue berry. if u READ my posts.
i have a catless DP with stock cat back. it sounds nice.
HB SS/tc can show u what a catless DP with straight pipes sounds like.
Beth and Dan have been nothing but nice to me. and they even helped with some other things.
they keep selling out of a lot of their materials so they have been replenishing it.
at least 5 different peoples solenoids have burned up after 3K plus miles. the spring rets weak. and doesnt the solenoid open. causing exptreme heat.
if u want an excuse for a turbo upgrade. go ahead man
dont try to bash what u dont know broda.
btw why would u want to just to hot side piping. why not both?
Old Jun 2, 2009 | 05:32 PM
  #52
purplehaze03's Avatar
Originally Posted by Terminator2
I took my dejon spring out because I was seeing some flutter when letting off the throttle, and few have had issues with burnt out BPV solenoids. I thought better safe than sorry in this case. I think the stock exhaust with a Catless DP sounds pretty good but I like the way mine is now a lot better. When I first got my Catback It was kinda raspy and popped back some but it sounds better now as the muffler has broken in.
i called and talked to dejon powerhouse........ they have had no reported issues with the spring upgrade and according to their research and development if it is installed correctly should not affect the car, just change the sound.
Old Jun 2, 2009 | 05:35 PM
  #53
reign1's Avatar
course a company would stick up for their own product. lol
this isnt wal mart we are talking bout here. lol
Old Jun 2, 2009 | 05:39 PM
  #54
why is the spring bad i know i have read about how it is stiff and doesnt allow alot of airflow out etc. but the stock spring with an intake and performance parts flutters and doesnt hold boost as well
Old Jun 2, 2009 | 05:42 PM
  #55
1badBlueberrySC's Avatar
I know you are not referring to me with the "broda"
Well once again... if you read my buddy is making me a custom cold pipe! Same guy who did my custom intercooler!
Old Jun 2, 2009 | 05:55 PM
  #56
reign1's Avatar
no u i'dint......
lol
didnt know that. i dont follow peoples every move....
im not a stalker....
like HIValiscious......with 13 year old girls.... lols
companies who design turbos do think this through. and yes the spring is good for a little while. but is flawed but the spring eventually weakens. and u cant really tell it is until ur turbo is flutterdumping (which sounds amazing)
but u dont want to burn the solenoid.
Old Jun 2, 2009 | 06:01 PM
  #57
FutureEcotecOwner's Avatar
I noticed everyone is always saying that CIA and Hahns catless DP wont throw a code aslong as you have a tune. Now my question is, are we talking tuning your car right after you get the DP, or whenever? I got my Trifecta tuner a few months ago, and I plan on getting my DP sometime this month, so do I need a re-tune or what?
Old Jun 2, 2009 | 06:11 PM
  #58
reign1's Avatar
actually yes u need to retune with catless.
i had catless b4 the tune for a week. luckily no codes. my tuner told me i might get one but i didnt. i still have no code.
Old Jun 2, 2009 | 06:20 PM
  #59
I didn't retune mine after my d/p install and it's running just as strong... actually stronger than it was before with no codes!
Old Jun 2, 2009 | 06:36 PM
  #60
reign1's Avatar
yeah bc its catless man.
re tune and see the diff
Old Jun 2, 2009 | 06:38 PM
  #61
I tune my car more than prolly 80% of this site... usually every few days...
I am not going to change anything untill the car relearns the new airflow... which will be a few days!
Old Jun 2, 2009 | 06:39 PM
  #62
I'm just gonna pay the $75 and get the tuner from Trifecta again when I order my catless DP, so I can re-tune for the DP and raise the rev limiter or completely get rid of it. I know our cars dont make any power above the 6300rpms or so, but what can are cars safely rev to without blowing the motor, 7000rpms or so??
Old Jun 2, 2009 | 06:40 PM
  #63
6500 is as high as you need to go! I have mine at 7200 but never shift over 7000
Old Jun 2, 2009 | 06:54 PM
  #64
I wouldnt ever shift above 6500 unless I knew my car was making power above that and if I knew my engine wouldnt blow. I figured I might aswell get rid of it since I'm just gonna raise it to like 7k or so.
Old Jun 3, 2009 | 03:27 PM
  #65
Terminator2's Avatar
There is not much else he can do to that tune of his except maybe a few A/F and timing changes. Unless you are changing intakes or running nitrous you dont really need to retune these things after modding. Factory wideband takes care of it for you.
Oh, and I will have some changes to email you soon hopefully.
Old Jun 3, 2009 | 04:54 PM
  #66
reign1's Avatar
ooOoooOo please send. btw lemme know bout that intercooler too man
Old Jun 5, 2009 | 02:30 PM
  #67
ClearImageAuto Dan's Avatar
I just wanted to clear a few things up.
[QUOTE=redstarpa69;3942815]DO NOT STRETCH THE O2 SENSOR/WIRING - if you did - you could and will strip the wiring from the sensor, that's because the motor will move back and forth, its happen to a few guys already, that's why most guys returned the CIA & ZZP DP's.. that plus CEL kept coming on even if CEL got tuned out..
We have NEVER had any of our TC down-pipe returned for any reason. Our O2 sensor bung is perfectly placed and the wires are NOT stretched in any way. Please make sure you have your facts straight before posting a comment like this as it could be very damaging. Thanks.
CIA... was my first choice but they told me they wouldn't split up the hot and cold side pipes so I went with a company that would!
Not true. We split the hot and cold side all the time. Beth nor I would NEVER have told you this. In fact, we advocate NOT changing the cold side tube as the factory piece is not all that restrictive and is a pain to swap out. Especially on the HHR's. We deduct $70.00 when a customer deletes the cold side boost tube.
Originally Posted by fredds-turbaltSS
Yeah, i have the Hahn CAI, CIA IC Piping and i just ordered my ZZP DP. CIA turned me off simply bc iv been waiting for over 2 months since the GB has ended for my IC Piping
We do realize it took longer than we expected to get the initial boost tubing orders shipped. But you have to consider a "GB" is made available to the members to get them the absolute best price for the same quality. This means we must also shop for the best price on material, parts, tubing, clamps, silicone, etc. Like the old cliche goes: quality, low price and fast shipping. Pick two. You guys got the best price offered by any company for the absolute highest quality boost tubing kit available anywhere. But shipping took some time.
Tuning is not required for the DP specifically. You already have the tune so unless you are just looking for some other changes, you are fine. However, I keep forgetting to mention Vince of TriFecta has recently been able to crack another part of the factory tune parameters. he believes he may be able to unleash another 20 to 30 HP. So hold off on the re-tune for now.
To everyone else who has supported us, thanks very much.
Old Aug 25, 2009 | 12:31 PM
  #68
IslangD's Avatar
well fredds...
That is the pipe right there... just installed it 3 days ago. Fitment was SPOT on, but since I got the first with the angled bung it was a WEE too far but I managed to get the o2 screwed in.
I told them about the issue, and they are going to fix it.. by moving it 1-1.5" closer to the turbo so no more "VERY" tight wiring!
How much was your Downpipe? 239 or 189?
Old Aug 27, 2009 | 10:18 AM
  #69
Zooomer's Avatar
Supporting Vendor
We have not changed the pricing of our downpipes but the options.
If you want an offroad pipe with NO O2 bung, it's under $200 in full 304 stainless. (all ZZP downpipes are 304, we don't sell an aluminized piece).
The price as shown on the site is with an O2 bung (no CEL light) but you can remove that via drop down for a lower price. All downpipes are in stock and ship the same day you order.
Old Aug 27, 2009 | 10:46 AM
  #70
Mine I believe was their original catless downpipe with the angled 02 bung....
I Have about 3000 miles on this pipe and love it!
Old Aug 27, 2009 | 10:50 AM
  #71
reign1's Avatar
man that was a dead thread brought back to life. i dont remember arguing with you blueberrie. lol
Old Aug 27, 2009 | 10:52 AM
  #72
I don't either... ha ha ha
oh well life goes on my man!
Old Aug 27, 2009 | 11:02 AM
  #73
Shibito's Avatar
I have a ZZP catless DP with no O2 bung. I absolutely love it and wouldn't buy any other dp. Price is absolutely unbeatable. I had the CEL tuned out before the car was even started after install and I haven't recieve a CEL for the DP at all.
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
Sep 27, 2015 08:53 PM
