does anyone else have this problem
this is the third time ive had to tighten this bolt and im still under 10k miles... right under the LSD the transmission bracket. the 2 bolts facing towards the driver side always come loose on me. when ever it starts to get loose my shifter starts to feel like rubber and its very rough to throw the shifter between gears. if i let the bolts get too lose i lost 5th gear and reverse.
also i barley launch the car ... ive probly launched it 5 times since ive been tuned and about 8 times b4 i was tuned. but im not sure why this always happens the bolts have a little lock on them but i think i might get locking washers to make them hold but idk if that would create too much of a gap and cause a bigger problem
and now i looked at the tranny mount from underneeth the car... theres a broken bolt so i pulled it out and some of it is still stuck in the mount....
is it hard to drop a tranny mount i think ill be able to grab it with some vice grips. and if i drop the mount do i need wood under it or will the other mount hold the weight. also specs on the bolts would be appreciated
