does anyone else have this problem
Old Aug 27, 2009 | 12:08 AM
dunit121's Avatar
this is the third time ive had to tighten this bolt and im still under 10k miles... right under the LSD the transmission bracket. the 2 bolts facing towards the driver side always come loose on me. when ever it starts to get loose my shifter starts to feel like rubber and its very rough to throw the shifter between gears. if i let the bolts get too lose i lost 5th gear and reverse.
Old Aug 27, 2009 | 12:27 AM
ecotecturbo's Avatar
I have never had that problem strange.
Old Aug 27, 2009 | 12:48 AM
koch1ar's Avatar
have the dealer work something out? maybe some loc-tite?
Old Aug 27, 2009 | 01:06 AM
Gyrocon's Avatar
wow... are your tranny mounts in good shape? just wondering what would cause this to move so much that the bolts work themselves lose.
Old Aug 27, 2009 | 01:05 PM
dunit121's Avatar
also i barley launch the car ... ive probly launched it 5 times since ive been tuned and about 8 times b4 i was tuned. but im not sure why this always happens the bolts have a little lock on them but i think i might get locking washers to make them hold but idk if that would create too much of a gap and cause a bigger problem
and now i looked at the tranny mount from underneeth the car... theres a broken bolt so i pulled it out and some of it is still stuck in the mount....
Old Aug 27, 2009 | 01:19 PM
northvibe's Avatar
well if you had a broken bolt...it could of helped cause the other bolts to work loose. if you dont want to warranty this you are going to have to tap them out.
Old Aug 27, 2009 | 01:37 PM
dunit121's Avatar
is it hard to drop a tranny mount i think ill be able to grab it with some vice grips. and if i drop the mount do i need wood under it or will the other mount hold the weight. also specs on the bolts would be appreciated
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
