DP Install question
Old Aug 13, 2012 | 09:03 PM
jmiller15's Avatar
DP Install question
Okie, my search really yielded nothing that answered my question completely.
I just picked up my turbo xs cat less dp this afternoon, and after work I tossed up up on stands and went to get to work.
I soaked all 7 bolts with penetrating spray for about an hour, but try and try as I may I could not crack them, not even an mm...
Any tips or tricks for a guy with limited resources and just hand tools.
Old Aug 13, 2012 | 09:09 PM
Frogstofall's Avatar
I used a llong extension and 1/2" drive tools with a breaker bar. Took everything I had to get those bastards loose. You might be able to get an impact on them if you have a long enough extension just please wear safety glasses. You should be anyways.
Old Aug 13, 2012 | 09:14 PM
Boostin15's Avatar
Safety glasses all the way!!
Old Aug 13, 2012 | 09:15 PM
You'd be surprised how many people don't wear them. Haha!
Old Aug 13, 2012 | 09:18 PM
Boostin15's Avatar
I learned my lesson
ryman416's Avatar
rust in the eye=not very fun
Old Aug 13, 2012 | 09:22 PM
jmiller15's Avatar
neither is penetrating lubricant in the mouth....
but yes safety glasses all the way!!!
I think I might run by canadian tire and pick up an electric impact, I do have a decent length extension and a knuckle.... I dunno lol ugh!
Old Aug 13, 2012 | 09:39 PM
09TcSedan's Avatar
how many miles do you have on it?
i put my catless on about 3 months ago by myself. the night before i soaked the **** out of them with PB blaster and the next morning i soaked them again. drove around for a little bit so the stock DP was hot,brought it to my buddies house and they popped right loose. i had about 39-40k on my car at the time.
be sure to soak the hell out of your o2 sensor also. that was maybe my biggest problem. i used a ratchet while taking the stock DP off and putting my catless on.
i put my stock DP back on to bring my car back in for warranty stuff and i used a air impact.
if your using a impact to put the nuts on just be careful not to strip the threads out or round off a nut.
while putting my catless DP back on a few weeks ago,i managed to back the stud out of the flange. it made me kind of leary,for some reason i feel i stripped the threads on the turbo flange. i was using a air impact lol
Old Aug 13, 2012 | 10:29 PM
jmiller15's Avatar
Maybe I'll just keep soaking it... And give it a go tomorrow after work... I'll soak it in the morning too... My O2 sensor gave me the least trouble it popped right out... And when I put it back I put anti seize lube on it...
I have about 45k km on the car as well...
Old Aug 13, 2012 | 10:32 PM
kdub1492's Avatar
Mine were a bitch to get off but I took an impact to them. When using a impact use just enough extension to make clearance on it
Old Aug 13, 2012 | 10:34 PM
Serpent_Servant10's Avatar
I changed my dp like a month ago and it was a PITA. Using a longer wrench (mine was about a foot long), soaking with penetrating fluid, and giving it hell should get them loose. A lot of times is they rust/weld together so you may want to use your body weight. I had a mechanic even say that heating the bolts up will help too.
Old Aug 13, 2012 | 10:35 PM
BlackARCA06's Avatar
Impact. Took me 30 minutes besides my 02 sensor being a pita.
Old Aug 13, 2012 | 10:50 PM
Heat is definitely a good tool if you can use it safely.
Old Aug 13, 2012 | 11:02 PM
jmiller15's Avatar
so maybe a propane torch? (with no fluid on it haha)
I dunno CT has a cordless impact wrench 1/2" with a full tool set... for 119.00 right now it'll do about 1,050 in-lb of torque..Should get the job done!
Old Aug 13, 2012 | 11:14 PM
Ehhh... 1000 in-lb is only like 90 ft-lbs. That aint gonna do jack.
I have a porpane torch I use and it has kind of a long neck. I imagine it would be perfect for this so long as you clean up the penetrating oil you sprayed every where.
Old Aug 13, 2012 | 11:20 PM
jmiller15's Avatar
Haha next post, uh guys I started my car on fire....
Seriously going to try giving her a full day soaking in pen lube... I'll put it back up tomorrow after work...
Thinking maybe a 15mm open ended and a hammer if needed could work too?
In anycase I am loving the DP not being on lol, its sitting on my couch right now and sexy as all hell!
Turbo xs does one hell of a job!!!
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Extremespeed
Sep 29, 2015 04:34 AM
Bohb
Sep 27, 2015 09:11 PM
